One more 102 fpd
One more 102 fpd
2006-01-03 by strohs56k
I put up another fpd proposal for the 102 "motm-102-sms.fpd"  I fooled
with the jack layout to make it (at least to me) more cascade
friendly.  (And I switched clock cv for a asr/loop control jack.)
seth
Re: One more 102 fpd (one last idea about looping)
One last idea from me regarding the asr/loop mode.  Could the switch
be a three position so we could have 4 step (a -> b -> c -> d -> a)
and 3 step (a -> b -> c -> a) loops?  It seems rhythmically useful to
have both an even and an odd length loop available.  You could also
have this functionality on the control input (the jack) using a
positive voltage (a normal gate signal) for the 4 step pattern and a
negative voltage for the 3 step pattern.  "zero" volts for ASR mode.
With no jack plugged into the control input the switch takes over.
seth
> seth
RE: [motm] One more 102 fpd
2006-01-03 by John Loffink
I like this one better than mine.  I had forgotten about the external
LOOP/ASR control jack.  That is very useful.
John Loffink
> -----Original Message-----
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
> strohs56k
> Sent: Monday, January 02, 2006 11:56 PM
> To: motm@yahoogroups.com
> Subject: [motm] One more 102 fpd
> seth
