S&H talk
2006-01-03 by Paul Schreiber
OK, let's do this: a) 1U wide b) S&H functions only c) 14-bit accuracy for VCO pitch accuracy Minimum features a) internal clock b) +-/- edge switch select Possible features: a) Output correlate pot b) internal clock is CV'd (input jack + possible attenuator pot) c) CLK OUT jack d) switch to select ASR mode or a 'Cycle' mode so Pulse #1> Out 1, Pulse #2>Out #2, etc. If there were say 4 outputs, *each* output is updated every 4th pulse. OK, so what I need is a FPE panel design! I'll order one this week along with all my other FPE panels. I do like tick marks on the pots :) If you don't have FPE, it's a quick and easy PC download www.frontpanelexpress.com Paul S.
