MOTM ribbon controllers - Doepfer and PAIA?
2005-09-26 by ivancu@aol.com
2005-09-26 by J. Larry Hendry
>http://www.tellun.com/motm/diy/tln854/TLN-854.htmlGreat stuff; thanks!
>As soon as all my cables are shipped, we will be starting up the panel
>process full steam.
2005-09-26 by tontaub
>> Silly question - will the CV output of the panel be raw, non-quantizedAs far as I understand Scott's project: sure!
>> information? I want to be able to use the CV out as a source of
>> continous control voltages like the "old fashioned" ribbon controllers.
2005-09-30 by Scott Juskiw
>I'm using the original R2M hardware at the moment and I also have hope
>that the "glitch-problem" will be ironed out with the more reliable
>analouge path Scott's circuit provides. *)
>I'm not a big fan of Doepfer hardware but unfortunately a Ribbon
>Controller is not a widespread gadget :-(
> HTH, Michael.
>*) My R2M's CV is not smooth. I can't see exactly what it is, I just
>can hear it. A simple LP-Filter in the CV path eases this problem. I
>got two examples I made to show:
>First the VCF's frequency modulated by an LFO (4 ups) and then
>manually by using the pressure sensor of the R2M:
>http://bluemole.com/misc/r2m-glitches.mp3
>Then with the filter hooked up. First out, then in:
>http://bluemole.com/misc/r2m-glitches_filtered.mp3
2005-10-22 by Michael Zacherl (aka TonTaub)
> I'm not sure why you are having that glitching problem with theas I understood the original version needs much more pressure applied to
> pressure output. Mine is quite smooth. They did replace the pressure
> sensor recently, perhaps that's part of the problem (I have the
> original version).
>> non-quantized
>>>> controllers.
>> HTH, Michael.
