Soldering Iron temp, did I screw up.....
2005-07-28 by Chris //
Alright so I picked up a WP35 soldering iron (850F) like stated in the motm PDF, built 2x800 ADSR and a 420VCF (havent booted them up yet as I am waiting for power).
About to start the 380 Quad Lfo and I come across 'use 700F tip/temperature', so I go thru the archives and now I am thinking, should I be worried, could I have killed some parts??? Should I look into buying a new soldering iron before contining????
Chris
Re: [motm] Soldering Iron temp, did I screw up.....
2005-07-28 by Scott E.
Chris,
The only issue would be if you held heat too long against a component.
700 degrees is kind of a standard temp for most irons. Higher tip temps
are no problem if one understands that you should hold the iron in place
as long as a lower temp tip. It is not uncommon to see 800+ degree irons
used in production environments, but it takes a bit more skill to use, IMO.
It is probably best for DIY users to have a 700 degree setting.
Scott
> Thanks
> Chris
> SPONSORED LINKS
> Cd music label
> <http://groups.yahoo.com/gads?t=ms&k=Cd+music+label&w1=Cd+music+label&c=1&s=20&.sig=PN1W4h6coCCCHlooBOMqhQ>
> YAHOO! GROUPS LINKS
>     *  Visit your group "motm <http://groups.yahoo.com/group/motm>" on
>       the web.
>     *  To unsubscribe from this group, send an email to:
>        motm-unsubscribe@yahoogroups.com
>       <mailto:motm-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2005-07-28 by synth1@airmail.net
> waiting for power).
I'm sorry if it says 850F in the PDF (Don't have it handy, I'm out of the
office), but 700F is correct. Most Wellers only need a $6 new tip
replacement, not the whole iron.
Thanks for the info, the PDF does not say 850F, it just lists the Weller WP35P as an option for a soldering iron, I will look into a new tip before I look into buying a WTCPT..
thanks
Chris
Sent: Thursday, July 28, 2005 2:37 PM
Subject: Re: [motm] Soldering Iron temp, did I screw up.....
> waiting for power).
