FW: HELP! MOTM-800 Box Caps
1999-11-08 by Tkacs, Ken
Actually, I made a typo:
The guide says that one should be 1000pf marked E102, and the other,
0.01 mfd stamped D103.
To: 'motm@onelist.com'
Sent: 11/8/99 11:26 AM
Subject: Re: [motm] HELP! MOTM-800 Box Caps
On Mon, 8 Nov 1999, Tkacs, Ken wrote:
> I'm home from work building my modules today. I'm halfway through the
800 EG
> and I'm stuck on the "yellow box caps." The manual says they should be
> marked "102" & "104" but mine are "1n0 J 63*" and "10n J 63*"
  I'm not Paul, but here is how these codes work:
  102 = 10 x 10^2  x 10^-12 = 1000 picofarads = 0.001 microfarads
  104 = 10 x 10^4 x 10^-12 = 100,000 picofarads = 0.1 microfarads
  1n0 = 1.0 "nanofarads" = 1 x 10^-9, = 1000 x 10^-12 = 0.001
microfarads
  10n = 10 nanofarads = 10 x 10^-9 = 0.01 microfarads
  100n = 100 nanofarads = 100 x 10^-9 = 0.1 microfarads
  Are you sure the one cap isn't a 100n  ?
  --Scott
Thanks to both of you!
---Ken Tkacs
To: motm@onelist.com
Sent: 11/8/99 11:39 AM
800
EG
be
microfarads
 In addition, the J means 5% tolerance and the 63 means 63VDC rated.
Crow is right, 1n = .001uf, 10n = 0.01uf, 100n = 0.1uf.
The nf is strictly a European thing.
remembers mmf (pre-picofarad)
