Need 2 beta testers
2005-03-04 by Paul Schreiber
I need 2 beta testers for the VC Pulse Divider prototype. Here are the
*requirements* :
a) have a MOTM-950 supply or have one on order (which means I'll bill you and
send it with the proto). OR...place an order for one :)
b) the prototype is *not* a 'module'. It is a pcb about 8 x 10 inches. It needs
to lie flat on a surface (not dangling in space) within 24in of the MOTM-950.
The jacks are pcb mounted along the 'edges' of the board. There are some
switches and pots also soldered on the board.
c) Although you can run audio through it (up to about 14Khz) that's not the
*primary* use. It's a "clocking" module that sits in-between say a LFO and a
sequencer. The input can be any thru-zero wave, but the outputs of the divider
are (currently) 50% duty cycle square waves of about 0 to +4V. I need testers
that have 'things' with external clock inputs.
d) there is a 'stepped' CV output that is set for 4ths/octaves/5ths that you can
drive VCOs, VCFs, etc with. Fixed at 8 steps, but driven by either the input
clock or the /N clock (switch selected).
e) you HAVE to mess with it for some decent time by April 1st. And I don't mean
"Oh Sh-t, Paul is going to call me tomorrow! I'd better *find* it!".
So, if you qualify please send me a *PRIVATE* email.
*requirements* :
