Interesting feedback patch
2005-01-15 by John Loffink
Required ingredients:
MOTM LFO or VCO with square/pulse output (LFO)
MOTM-800 EG (EG)
Tellun Labs Neural Agonizer (NA)
Blacet Time Machine (TM)
Encore Frequency Shifter (FS)
Patching:
LFO pulse output to EG gate input
EG Out+ to Neural Agonizer Feedback (CV input)
NA Feedback Out to TM In
TM Out to FS In
FS Out to NA Feedback In
NA Mix Out to external LIMITER or COMPRESSOR set up as a limiter (THIS IS
IMPORTANT FOR YOUR SPEAKER'S and HEARING'S SAFETY)
Knob settings:
LFO at 0.5 to 5 Hz rate
Set EG to low ADSR settings
TM
TM Mod Mix set to internal
TM Rate > 2
TM Depth > 2
Start with NA LPF set to minimum, carefully raise the level
Other settings to taste
If you get into a feedback howl the quickest cure is to turn the NA LPF to
zero
Result:  Controlled feedback with NO input to the Neural Agonizer.
John Loffink
