Fw: [motm] Pass through holes?
2005-01-14 by groovyshaman
This was meant to go to the group...
To: "sduck409" <sduck409@...>
Sent: Thursday, January 13, 2005 11:50 PM
Subject: Re: [motm] Pass through holes?
> One suggestion - if you plan to go back over the boards to solder the vias
> AFTER all of the other components have been soldered, use no-clean solder.
> Using organic solder would require you to wash the board again, and some
> parts would not respond well to that (such as pots).  Especially if you
wash
> in tap water and not distilled, as that can leave a mineral residue.
> Actually I'm curious, does anyone else do a once over on their boards with
> distilled water, after scrubbing under the tap?
> George
> From: "sduck409" <sduck409@...>
> To: <motm@yahoogroups.com>
> Sent: Thursday, January 13, 2005 11:13 PM
> Subject: [motm] Pass through holes?
> > So I was soldering up the prestuffed resistors on my 480 this evening
> > (mmm...prestuffed! I could get used to this luxury...) and I had this
> > nagging question that I thought might be apropriate for this board. I
> > noticed this pcb has lots of pass through holes, or whatever those
> > little holes are called. Some of the kits have instructions to seek
> > out and fill these holes, and some of the kits don't (the 480
> > quick-kit doesn't mention them). My guess is that it has something to
> > do with who manufactures the board, and/or the board design. Does
> > anyone have any further insight on this? Should I just be filling them
> > willy-nilly? Just for the heck of it I filled some of them on the 480
> > board, but there are a LOT of them - getting them all would be a large
> > undertaking.
> > Steve Drake
Re: Fw: [motm] Pass through holes?
2005-01-14 by Scott E.
ALWAYS.
Scott E.
> boards with
> > George
2005-01-14 by Jim Carlile
My brother is in the aquarium maintenance business and I always use
the water he has in a holding drum. I know it passes through a RO
filter and some other stuff, so it is super pure.  I don't think it
really matters that much as long as you thoroughly dry of the PCB,
but the tap water at my location tastes noticeably .. different.
the vias
clean solder.
and some
if you
> wash
residue.
boards with
2005-01-15 by Richard Brewster
Yes, me too.
-Richard Brewster
Scott E. wrote:
>ALWAYS.
>Scott E.
>>boards with
>>>George
