Blue LEDs?
2004-11-15 by musik_arbeiter
Is there any electrical reason why I couldn't simply swap the red LEDs on my 101 and 390 modules for blue ones, or possibly some other nice color like ultraviolet or sea green? Would I have to do anything besides just soldering one in place of the other?
2004-11-15 by Scott Juskiw
At 5:30 AM +0000 2004/11/15, musik_arbeiter wrote: >Is there any electrical reason why I couldn't simply swap the red LEDs >on my 101 and 390 modules for blue ones, or possibly some other nice >color like ultraviolet or sea green? Would I have to do anything >besides just soldering one in place of the other? In most cases you can't just swap the LEDs. The biggest problem with blue LEDs is that they are much brighter than your typical red or green LED (although there are also high brightness red and green LEDs available). To decrease the brightness, you'll need to increase the current limiting resistor substantially. I will typically increase a 1.5K resistor to 15K when swapping from a red to a blue LED to keep from going blind. If you've ever seen the blue LED on the back of an Andromeda, you'll know what I mean (I keep mine covered up with black electrical tape). The 101 is even trickier to do an LED swap because the forward voltage drop across the LED is different and changing the current limiting resistor affects performance. So you can't just swap LEDs and change resistors. I've got some notes on using a blue LED with a 101: http://www.tellun.com/motm/mods/motm101/motm101.html I can't comment on the 390 because I haven't built mine yet, but I will likely change the LEDs in it as well when I get around to building them. BTW, careful with violet LEDs because they do generate ultraviolet light which is bad for your eyes.
2004-11-16 by Mike Estee
>> Also, It's not an electrical reason, but looking at UV and bright blue >> LEDs is not that great for your eyeballs. You'll also probably drop >> the >> resale value of your modules, or maybe not. It's also impossible to >> find the MOTM style led in blue, aqua, or UV. > > Yeah, look out for the bright LEDs. The red ones in my Waldorf Micro-Q > are > *NASTY*. I angled my rack just to avoid looking at them. Anything with > a > diffused lense should be OK, but the clear ones are eye killers. Yeah, I remember those! For an extremely misguided example of LED torture check out the new Access Virus "Polar". http://www.access-music.de/ Ugh. --mikes
2004-11-17 by djbrow54
I have substituted the green Lumex leds (from Digikey) for many of the red leds when I build MOTM modules. I generally prefer more green and use the red leds for indicators such as clipping. I bought extra leds and reuse the housing to mount bicolor and blue leds. I have to trim the tabs inside the housing for these leds to fit. The Chicago bicolor leds fit and work just great. These alternate leds are the standard dome shape and are too long and extend out of the housing. I simply grind off the top of the led to flatten them and create a nice diffused surface. I then use sandpaper in a rotary motion to smooth them off and leave a circular pattern on the surface. I use bicolor to indicate signal polarity such as on the MOTM-320 LFO. They aren't as bright as the MOTM bicolors but look quite good. I use blue to indicate MIDI for my Roland Sound Canvas module and my Expressionmate Ribbon module. I wouldn't want a whole panel of blue. It would be hard on my eyes. Dave --- In motm@yahoogroups.com, "musik_arbeiter" <nickca@g...> wrote: > > Is there any electrical reason why I couldn't simply swap the red LEDs
> on my 101 and 390 modules for blue ones, or possibly some other nice > color like ultraviolet or sea green? Would I have to do anything > besides just soldering one in place of the other?
