How do I use the "Bias" switch? MOTM-830
2004-08-18 by earthtodylan2000
 I've just built my first batch of MOTM modules.  They were fun to
build and worked right off the bat.  I am confused about the
function of the Bias switch on the MOTM-830 dual mode mixer.
What does it mean that it sends DC voltage?  How do I use that?
What is it good for?
 Thanks.  I'm still green as far modular synths go!
Re: [motm] How do I use the "Bias" switch? MOTM-830
2004-08-18 by synth1@airmail.net
It adds a fied voltage to the output. So, if the inputs are all of (zero),
then you can view it as "sending" out a fixed DC voltage.
>  How do I use that?
Put the switch in the ON position :)
Some modules want 0 to +5V inputs (like resonance CVs on the filters).
What if you want to use the output of a LFO, that is -5V to +5 V?
Ponder and the answer will come.
Re: How do I use the "Bias" switch? MOTM-830
2004-08-19 by djbrow54
I find I use mine a reasonable amount.  I can run it into a
comparator
and use it to set the threshold.  I can offset my ribbon controller
for doing modulations.  I have used it as a source of +5V to switch
with a MOTM-700 for creating gates.  I've used it into a mixer to
create some 10 volts waveforms for older equipment.  I also use it a
lot to debug new modules.
Dave
--- In motm@yahoogroups.com, "earthtodylan2000" <sir_dss@h...> wrote:
> Hi,
