AC coupled, DC coupled
2004-01-09 by Robert van der Kamp
Hi all,
could someone try to explain in layman's terms what it means
when an input is either AC or DC coupled?
I know it means it assumes either an AC or DC signal. But
what if I feed it the other type of signal?
And a related question: what is the definitions of an AC and
DC signal, in modular context? For example, when I an EG
ouputs a through-zero DC signal, isn't that actually an AC
signal?
Confused...
- Robert
Re: [motm] AC coupled, DC coupled
2004-01-09 by Richard Brewster
Here is a simple explanation:  DC (direct curent) means a steady,
unchanging voltage, which could be any voltage level.  If a circuit is
DC-coupled it means that the level of an unchanging voltage at the input
will be passed through.  If a circuit is AC coupled then only changing
voltages will be passed and there will be a "high pass" function
applied, i.e. there will be a frequency below which signals won't pass.
This cutoff frequency is normally about 20 Hz  for audio processing.  If
you look at a circuit diagram, you will see a capacitor in series with
the signal path if it is AC coupled.  Both inputs and outputs can be AC
coupled.
If you feed a DC voltage, say +5V, into an AC coupled input, the output
will be zero.  You can always feed an AC signal into a DC coupled
input.  That works fine.  So why not always just use DC coupling?
The benefit of AC coupling is that it removes any DC offset (constant)
voltage.  For example, the signal input of a VCA is sometimes AC
coupled, because a DC offset at the signal input can result in a popping
sound when it is multiplied with the control input.  The control input
of a VCA has to be DC coupled, or else a prolonged unchanging voltage,
such as the sustain portion of an envelope, would not produce the
desired constant output level.
Good question about the EG output.  It is DC coupled, for the reason
above.  However, an envelope is a type of AC signal, because it changes
over time.  The interesting thing about an envelope is that it combines
different frequencies in one cycle.  Attack is typically fast, decay and
release slower.  An attack time of 20 milliseconds is 1/50 of a second,
i.e. 50 Hz, up in the AC range for sure.  But a 500 millisecond release
time is only 2 Hz.  So it is an AC signal with some very low frequency
parts.
-Richard Brewster
Robert van der Kamp wrote:
>Hi all,
>signal?
>Confused...
>- Robert
2004-01-09 by Mark
On 1/9/04, Richard Brewster put forth:
>parts.
The output of an MOTM 800 is not an AC signal.  It is a positive
voltage that never crosses zero.  AC stands for "alternating current"
-- it "pushes" current one way when the voltage is positive, and
"draws" current the other way when its voltage is negative.
Most audio inputs are AC coupled.  Their inputs have "blocking
capacitors" to remove DC offset.  Most CV inputs are DC coupled --
they can accept both AC and DC signals.  There is a difference
between AC and DC coupling when doing ring modulation, oscillator FM,
etc., but understanding this difference is very important when using
patching filters and VCA's.  The modulation inputs are DC coupled,
but the signal inputs are usually AC coupled.
For example, one VCA in each of the MOTM dual VCA's can be used to
process control voltages (the 110 has a switch allowing you to bypass
the capacitors) so that they can be used to control modulation depth.
The other VCA in each dual VCA is AC coupled, so it can only be used
to process audio signals.  The 820 lag processor functions as
DC-coupled low-pass filter.  It can be used to process control
voltages and audio signals.  Afaik, all of the other MOTM filters
have AC coupled inputs, so they cannot process control voltages.  If
you try to ignore this, your patch won't "work".
> steady, unchanging voltage, which could be any voltage
> level.  If a circuit is DC-coupled it means that the
> level of an unchanging voltage at the input will be
> changing voltages will be passed and there will be a
> "high pass" function applied, i.e. there will be a
> frequency below which signals won't pass. This cutoff
> If you look at a circuit diagram, you will see a
> capacitor in series with the signal path if it is AC
> coupled.  Both inputs and outputs can be AC coupled.
I see. Is there also a low pass function applied on AC
coupled circuits, at say 20 kHz?
> input, the output will be zero.  You can always feed an
> AC signal into a DC coupled input.
Ah, this helps! So I can go anywhere on my modular with an
AC signal, on both AC and DC coupled inputs. Is that
because a DC coupled input 'sees' the AC signal as a
quickly changing series of 'unchanging voltage levels'?
> offset (constant) voltage.  For example, the signal input
> of a VCA is sometimes AC coupled, because a DC offset at
> the signal input can result in a popping sound when it is
Okay.
>  The control input of
> unchanging voltage, such as the sustain portion of an
> envelope, would not produce the desired constant output
> level.
Understood.
Thanks Richard, that helped a lot!
- Robert
> positive voltage that never crosses zero.  AC stands for
> "alternating current" -- it "pushes" current one way when
> the voltage is positive, and "draws" current the other
Ah, I see.
> "blocking capacitors" to remove DC offset.  Most CV
> inputs are DC coupled -- they can accept both AC and DC
> signals.
Yes, that's what I just learned from Richards post. Never
new this, but it's an eye opener for me.
>  There is a difference between AC and DC
> coupling when doing ring modulation, oscillator FM, etc.,
> using patching filters and VCA's.  The modulation inputs
> are DC coupled, but the signal inputs are usually AC
> coupled.
> be used to process control voltages (the 110 has a switch
> allowing you to bypass the capacitors) so that they can
> be used to control modulation depth. The other VCA in
> each dual VCA is AC coupled, so it can only be used to
Aha, that's why Paul recently said that only VCA #2 in the
190 can be used for DC signals. That input must be DC
coupled, while input #1 is AC coupled, I assume. So that
means that input #2 of the 190 cannot handle DC shift and
could cause pops in the sound. Correct?
> as DC-coupled low-pass filter.  It can be used to process
> control voltages and audio signals.  Afaik, all of the
> other MOTM filters have AC coupled inputs, so they cannot
> process control voltages.  If you try to ignore this,
I'm starting to understand this now.
I never understood the fact that I can apply an LFO to a DC
coupled (CV) input. I always assumed that an LFO must be a
DC signal, since it was used for DC coupled inputs. But an
LFO is just a slow moving audio signal, very AC. I didn't
understand. But now that I know that DC coupled inputs also
accept AC signals, the whole LFO issue is finally
understood. :)
Robert
Re: AC coupled, DC coupled
2004-01-09 by strohs56k
> current" -- it "pushes" current one way when the voltage is
> positive, and "draws" current the other way when its voltage is
> negative.
An EG could be classified as a DC source or an AC source depending
upon which part of the envelope cycle is active.  In the "off" state
(at zero) and in the sustain state the EG outputs a constant DC
voltage.  In the attack, decay, and release state the EG outputs a
time varying voltage which is essentially an AC waveform.
A signal does not need to "cross zero" to be considered AC.  For
example, you could take a sine wave (AC) that is 2 volts peak to peak
and add a 1 volt DC offset.  You still have a sine wave (AC) but
instead of going from -1 volts to +1 volts, you now have a waveform
that goes from 0 volts to 2 volts.  (It is still AC but it never
crosses zero.)
Using that same example, we can think about AC coupled and DC coupled
inputs.
If an input is AC coupled, it rejects DC offset.  If we feed our
"normal" -1 to +1 sine wave into an AC coupled input, there is
essentially no change in the waveform.  (It remains a -1 to +1 sine
wave.)  On the other hand, if we feed our 0 to +2 sine wave into an AC
couple input, the DC offset of 1 volt is eliminated by the AC coupling
and what results is a "normal" -1 to +1 sine wave.
For DC coupled inputs, any DC offset remains in the signal.
2004-01-10 by Mark
On 1/9/04, Robert van der Kamp put forth:
It is a high pass filter, and the frequency is largely determined by
the size of the cap.
(However, a capacitor can also be used in a different configuration
as a low pass filter to reduce RF noise on low level inputs.  If no
other filters were used, it would still pass DC.)
I wouldn't say it couldn't handle an offset signal, but afaik, it's
not going to remove that offset.
On 1/9/04, strohs56k put forth:
Then you are using a different definition of the term.  The voltage
between the output and ground does vary, but the current doesn't
alternate.  I'm not trying to get into a semantic argument, but
merely offer advice on using the system.
In practice, if I switch the capacitors in series with both inputs of
the multiplier section of the 110, the output of an 800 does not
result in a working VCA.  One input must be DC-coupled for what I
consider a DC signal.  Likewise, I could patch the output of the 800
to the audio input of a filter and trigger the EG to "ring" that
filter, but I'm not going to be able to adjust a continuous flowing
effect that follows the voltage of the EG.
Right, we agree on what is happening.  We can look at that as a AC
signal riding on a DC offset -- that's what you would get if you
summed a bias voltage and AC signal on DC-coupled mixer.
2004-01-10 by mate_stubb
Two points:
1. We have started discussing AC vs DC signals.
AC usually implies periodic cycling or repeating of the voltage
pattern, such as a VCO waveform. However, an envelope generator that
normally puts out a transient DC voltage can put out an AC voltage if
being repeatedly triggered from an LFO, for instance.
If a cyclic waveform is symmetrical around zero volts, it is pure AC.
If not, it is AC with a DC component.
2. Think of DC coupled inputs and outputs as having the ability to
handle DC and/or AC. They pass everything on exactly as it came in.
An AC coupled input or output will filter out the DC component in the
signal but pass on the AC component. Apply a pure DC waveform to an
AC coupled input and it will have no effect, because it is completely
filtered.
Moe
http://www.hotrodmotm.com
