I have just received a new batch on BC560C PNP transistors used in almost every MOTM kit. The
clever amongst you will recall the BC560Cs are currently blue-ish silver on the facing (flat)
side while it's complementary kindred the BC550C is a standard black.
Be warned! The new BC560Cs are *also all black*. So, Master Yoda says:
"'Attention paying must careful be, when soldering transistors into the MOTM sea."
