Re: Shallow cases for MOTM
2003-07-17 by ivancu@aol.com
All of the custom case companies will build what you want; none will stock it since a case that shallow and tall is inherently unstable (depends how you distribute the rack gear as well). I received a quote recently for a 16-space rack that is 10" deep with 2.5" deep lids (a Power-One PSU will fit nicely in the rear lid). The total was $300 for this case. I have also looked into getting a rigidized aluminum case built, and it is closer to $400. If I went this route I might go for multiple 11-space racks and have them interlock: http://www.cyber-case.com/rackmount-case.htm Feel free to e-mail me if you want more info. I have bought MANY different brands of road cases over the years and can recommend some of the better ones. Freight is expensive on these so to find a good and local supplier makes sense. If cost is no object then just buy from R&R Cases: http://www.rrcases.com Ivan
>Message: 1 > \ufffd Date: Thu, 17 Jul 2003 02:40:34 -0000 > \ufffd From: "hciassociates" <mbfisher@...> >Subject: Shallow cases besides SKB? > >Anyone have ideas or suggestions for a shallow (say, 10" depth or >less), tall and/or stackable rack case for a MOTM system?
