stooge industries to the rescue..?
2003-07-08 by Sikorsky
hello all,
i don't know if anyone else has the same problem, but you know when you've
just put that new module together, you put it in your rack, power it up, hey
presto - it works
but:
oh no - it needs calibrating !
so you power down, pull the module out and try balancing it sideways while
you get to the trimpots
but what if the phone rings / you left the bath running / relatives call
round..?
if only someone were to offer a set of four steel extenders, one end bolts
to the rack, the other end attaches to the module with a little thumbscrew
good idea?
anyone?
cheers
paul b
sheffield
uk
Re: stooge industries to the rescue..?
2003-07-08 by Mike Marsh
Ha!  WHat a great idea!  I ususally have to let mine hang
precariously from the power cable and do yoga to get to the
adjustment pots.
I'm going to cook some of these up from dowels and threaded
inserts.  I'll post pics this weekend...
Mike
--- In motm@yahoogroups.com, "Sikorsky" <vulture.squadron@s...>
wrote:
> hello all,
when you've
it up, hey
> presto - it works
> but:
sideways while
relatives call
> round..?
end bolts
thumbscrew
> good idea?
> anyone?
> cheers
> paul b
> sheffield
> uk
This is better because you don't need an alligator clip rig to
ground the panel...?
--- In motm@yahoogroups.com, "J. Larry Hendry" <jlarryh@i...> wrote:
> I have an alternate idea:  They have this stuff at the hardware
store called
> "all thread"  It is a long threaded steel rod.  You cut them to
length with
> a hack saw.  I am 99% certain they come in # 8/32 format.  So, get
yourself
> a 3 foot piece of this, cut into 4 equal parts, apply 4 nuts for
panel
> stopper and get 4 wing nuts for the front.
> Simply screw it into the rack or flat rail and you can attach the
module
> right to it.  if you overseas guys cannot find it, I'll be happy
to get you
> some. (after vacation)
> Stooge Larry
> From: Mike Marsh <mmarsh@w...>
precariously from
> adjustment pots.
inserts.  I'll
Re: [motm] Re: stooge industries to the rescue..?
2003-07-08 by J. Larry Hendry
I have an alternate idea:  They have this stuff at the hardware store called
"all thread"  It is a long threaded steel rod.  You cut them to length with
a hack saw.  I am 99% certain they come in # 8/32 format.  So, get yourself
a 3 foot piece of this, cut into 4 equal parts, apply 4 nuts for panel
Simply screw it into the rack or flat rail and you can attach the module
right to it.  if you overseas guys cannot find it, I'll be happy to get you
Stooge Larry
Ha!  WHat a great idea!  I ususally have to let mine hang precariously from
adjustment pots.
I'm going to cook some of these up from dowels and threaded inserts.  I'll
Not better, just "alternate."
To: <motm@yahoogroups.com>
Sent: Tuesday, July 08, 2003 12:52 PM
Subject: [motm] Re: stooge industries to the rescue..?
store called
length with
yourself
panel
module
to get you
> Stooge Larry
precariously from
> adjustment pots.
inserts.  I'll
