MOTM-292 mockup?
2003-06-11 by Paul Schreiber
All you Photoshop geniuses see if a dual, triple, or Quad LPG makes sense. Having the CV jacks in a vertical column on the far left seems asking for trouble unless it's over in the "2nd" jack column. Paul S.
2003-06-11 by John Loffink
First we need to know what jacks and pots we need for those special MOTM only features. John Loffink jloffink@... The Microtonal Synthesis Web Site http://www.microtonal-synthesis.com/ The Wavemakers Modular and Integrated Synthesizer Web Site http://www.wavemakers-synth.com/ > > All you Photoshop geniuses see if a dual, triple, or Quad LPG makes sense.
> Having the CV jacks in > a vertical column on the far left seems asking for trouble unless it's > over in the "2nd" jack > column. > > Paul S. >
2003-06-11 by Mike Marsh
Does that mean GAIN pot, CV IN, IN, and OUT? Plus LED? You could fit two of those in a 1U. Mike --- In motm@yahoogroups.com, "Paul Schreiber" <synth1@a...> wrote: > Start with the basic setup, let's start there. > > Paul S. > > ----- Original Message ----- > From: "John Loffink" <jloffink@a...> > To: "'Paul Schreiber'" <synth1@a...>; "'MOTM listserv'" <motm@yahoogroups.com> > Sent: Wednesday, June 11, 2003 6:16 PM > Subject: RE: [motm] MOTM-292 mockup? > > > > First we need to know what jacks and pots we need for those special MOTM > > only features. > > > > John Loffink > > jloffink@a... > > > > The Microtonal Synthesis Web Site > > http://www.microtonal-synthesis.com/ > > > > The Wavemakers Modular and Integrated Synthesizer Web Site > > http://www.wavemakers-synth.com/ > > > > > > > > All you Photoshop geniuses see if a dual, triple, or Quad LPG makes > > sense. > > > Having the CV jacks in > > > a vertical column on the far left seems asking for trouble unless it's > > > over in the "2nd" jack > > > column. > > > > > > Paul S. > > > > > > > > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > >
Start with the basic setup, let's start there. Paul S. ----- Original Message -----
From: "John Loffink" <jloffink@...> To: "'Paul Schreiber'" <synth1@...>; "'MOTM listserv'" <motm@yahoogroups.com> Sent: Wednesday, June 11, 2003 6:16 PM Subject: RE: [motm] MOTM-292 mockup? > First we need to know what jacks and pots we need for those special MOTM > only features. > > John Loffink > jloffink@... > > The Microtonal Synthesis Web Site > http://www.microtonal-synthesis.com/ > > The Wavemakers Modular and Integrated Synthesizer Web Site > http://www.wavemakers-synth.com/ > > > > > All you Photoshop geniuses see if a dual, triple, or Quad LPG makes > sense. > > Having the CV jacks in > > a vertical column on the far left seems asking for trouble unless it's > > over in the "2nd" jack > > column. > > > > Paul S. > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
2003-06-12 by Paul Schreiber
Add a CV Mod pot per channel, and GAIN is not exactly "correct" INITIAL is better. Paul S. ----- Original Message -----
From: "Mike Marsh" <mmarsh@...> To: <motm@yahoogroups.com> Sent: Wednesday, June 11, 2003 6:39 PM Subject: [motm] Re: MOTM-292 mockup? > Does that mean GAIN pot, CV IN, IN, and OUT? Plus LED? You could > fit two of those in a 1U. > > Mike > > --- In motm@yahoogroups.com, "Paul Schreiber" <synth1@a...> wrote: > > Start with the basic setup, let's start there. > > > > Paul S. > > > > ----- Original Message ----- > > From: "John Loffink" <jloffink@a...> > > To: "'Paul Schreiber'" <synth1@a...>; "'MOTM listserv'" > <motm@yahoogroups.com> > > Sent: Wednesday, June 11, 2003 6:16 PM > > Subject: RE: [motm] MOTM-292 mockup? > > > > > > > First we need to know what jacks and pots we need for those > special MOTM > > > only features. > > > > > > John Loffink > > > jloffink@a... > > > > > > The Microtonal Synthesis Web Site > > > http://www.microtonal-synthesis.com/ > > > > > > The Wavemakers Modular and Integrated Synthesizer Web Site > > > http://www.wavemakers-synth.com/ > > > > > > > > > > > All you Photoshop geniuses see if a dual, triple, or Quad LPG > makes > > > sense. > > > > Having the CV jacks in > > > > a vertical column on the far left seems asking for trouble > unless it's > > > > over in the "2nd" jack > > > > column. > > > > > > > > Paul S. > > > > > > > > > > > > > > > > > > > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > > > > > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
2003-06-12 by Mark
On 6/11/03, Paul Schreiber put forth: > >Add a CV Mod pot per channel, and GAIN is not exactly "correct" >INITIAL is better. If you add a CV mod pot (two pots and three jacks per LPG), then two LPG's would not fit on 1U. If you decide on a 2U dual unit and add another jack and another knob per channel to add new features and fill up the panel, then you might as well make a 1U single LPG. No matter how you configure two LPG's in a dual unit, if each channel has the same amount of features, then result is always divisible by two :) Especailly considering that competing manufacturers offer LPG's, adding extra features seems important. Also, didn't the 292 have a "amplitude-both-frequency" switch for each channel?? That's a feature that might be worth keeping. Since most folks don't know what a LPG does, I think 1U module would sell better than a 2U module -- it would be less of risk. Anyone who wants more LPG's could just buy more modules :)
2003-06-12 by Mike Marsh
It *might* fit if you use smaller pots for the CV and a smaller knob and you scrunched up the jacks a little. Maybe even used smaller LEDs. BTW, the Cyndustries version also has the Amp-Both-Freq feature. Mike --- In motm@yahoogroups.com, Mark <yahoogroups@p...> wrote: > On 6/11/03, Paul Schreiber put forth: > > > >Add a CV Mod pot per channel, and GAIN is not exactly "correct" > >INITIAL is better. > > If you add a CV mod pot (two pots and three jacks per LPG), then two > LPG's would not fit on 1U. > > If you decide on a 2U dual unit and add another jack and another knob > per channel to add new features and fill up the panel, then you might > as well make a 1U single LPG. No matter how you configure two LPG's > in a dual unit, if each channel has the same amount of features, then > result is always divisible by two :) > > Especailly considering that competing manufacturers offer LPG's, adding > extra features seems important. Also, didn't the 292 have a > "amplitude-both-frequency" switch for each channel?? That's a > feature that might be worth keeping. > > Since most folks don't know what a LPG does, I think 1U module would > sell better than a 2U module -- it would be less of risk. Anyone who > wants more LPG's could just buy more modules :)
