uSeq function poll
uSeq function poll
2003-05-29 by Paul Schreiber
Need to see what the uSeq soon-to-be owners think about how to implement a certain operational
mode.
There is a mode called Gated Play. This is *currently* how the firmware is written:
a) Apply Gate/LFO signal to the GATE IN jack.
b) Without having to touch any uSeq controls, when GATE is high (greater than +2.5V), the uSeq
plays the sequence, starting at the fist note, at the specified tempo.
c) When GATE goes low, the uSeq *immediately* stops playing, de-asserts the GATE outs, and resets
the sequence to the beginning. When the GATE goes high again, back to (b).
d) If the user presses the STOP panel button while GATE is high, the uSeq *immediately* stops and
resets.
There is an additional 'constraint' I am pondering. If case (d) occurs, does the firmware
*require* the user to press PLAY in order to 'arm' the uSeq, and then when a GATE happens, it
operates as before.
The 'Pro' of the current firmware is that the uSeq becomes "hands free", meaning you can
start/stop it "remotely".
The 'Con' is that there is no way to "kill it" with physically killing the GATE (pulling patch
cord out/ceasing the GATE source).
Comments?
Re: [motm] uSeq function poll
2003-05-29 by Scott Juskiw
IMHO, the first commandment of modular synths is that everything
should be voltage controllable at all times, 24/7, manual
intervention is just an extra. With that in mind, pressing STOP
causes the thing to stop regardless of the GATE input. It should not
start up again until the GATE input goes low and then high again. We
shoudn't have to press PLAY again.
>mode.
>resets.
>operates as before.
Re: uSeq function poll
2003-05-29 by Mike Marsh
You are already requiring the user to press 'Stop', so it's no longer
hands-free.  Having the user press 'Start' again is preferred, rather
than pulling the patch cord, IMO.
Mike
> mode.
tempo.
to (b).
> resets.
> operates as before.
> Comments?
> Paul S.
2003-05-29 by mate_stubb
Seems to me that Mike is correct. If you do not hit 'Stop', the
starting and stopping is fully remote via the gate signal.
If you do hit 'Stop', well, you're already at the panel and you can
easily hit 'Start' to rearm it.
What I'd like to see added is an option to choose whether the
sequence resets to the beginning or plays from the current location
with each successive gate onset.
Moe
longer
rather
> Mike
Yes! I just did not have the guts to suggest it, but having the
option to 'ply thru' instead of restart would be very helpful.
Mike
> Moe
Re: [motm] Re: uSeq function poll
2003-05-29 by Adam Schabtach
It's already there. See section 6.3 of the spec.
--Adam
Cool.  I guess I understood from Paul's description that it was
restart only...
location
> --Adam
2003-05-29 by Scott Evans, Gen Mgr
I'm also of the mind that one should press start/play for the sequence
to resume.
S.
> mode.
> resets.
> operates as before.
> Comments?
> Paul S.
2003-05-30 by pacificamsx
I'm of the opinion that one should have to hit "play" in this situation.
-Russell
patch
> Comments?
> Paul S.
2003-05-30 by Jeffrey Pontius
Seems like I'm already in the minority, but I would prefer the "hands
free" option, if there is only one option to choose.  I'd prefer having
to cease a gate operation (e.g., run the gate through an attenuator), and
the 'remote' operation allows a lot more flexibility.
Jeff
2003-05-30 by J. Larry Hendry
I agree that hands free should be possible.  So, it can be started and
stopped remotely using the gate in.  I think the idea of having to pull the
cable is very bad.  Could it operate like this?
1.  complete remote start and stop, no intervention on the panel required.
Or, "as the gates flow."
2.  "Stop" on the panel overrides all remote gate start / stop function, so
when you hit stop in the "gated play "mode, it stops and stays stopped no
matter how many gates it receives.
3.  "Start" on the panel cancels the "stop" function and allows the restart
once gate input action resumes.
Seems like in the "gated play" mode start and stop could support that
function but would not actually be required use.  They would be almost like
"arm" and "disarm" buttons for the gate signals.
Larry H
Jeff
