Re: OT (Somewhat) Prog-Rock
2003-05-24 by paulhaneberg
2003-05-24 by Paul Schreiber
> Please excuse the somewhat off topic post.
> I just got list-member Eric Frampton's CD Agent Cooper.
2003-05-26 by Eric Frampton
> Free cherry pie with every order?nyak, nyak.
> Also: I love to listen to the "Twin Peaks" soundtrack while solderingFunny, even though we named the band after a character from it, I've
> Any MOTM content on the CD, Eric?The album was finished in '99, before I started down the MOTM road. The
2003-06-29 by Paul Wagorn
2003-06-29 by jwbarlow@aol.com
I'm kindof convnced that it's the instant jump from 0v to wherever the
waveform being output by the 300 just so happens to be wehn the env starts.
that would explain why bass notes are worse that higher notes (because the
waveform is longer therefore a voltage jump more often makes a steeper
'angle')
anyways, can MOTM not make bass notes...??? what's the deal? Should I just
not bother trying anymore?
/paul
(who all of a sudden likes his minimoog alot more since it doesn't click'
-----Original Message-----Try setting the GAIN on the '110 *ever so slightly* past the '0' point. Meaning, the VCA is *ever
Sent: Sunday, June 29, 2003 3:18 PM
To: motm@yahoogroups.com; Paul Wagorn
Subject: Re: [motm] my clicking & popping bass notes
so slightly* already on.
I know that you are convinced that "there is something wrong" with the MOTM system, but there's
not.
Maybe someone can send me some punchy, non-clicky bass MP3s to share?
2003-06-29 by Paul Schreiber
2003-06-30 by jwbarlow@aol.com
so, it's the vca.....
That would be my guess. I seem to recall there may have been some resistor tweaking with the 110 for the first few months after they shipped (wasn't the 110 one of the first three modules to ship?). I'm pretty sure I have some resistors in parallel (soldered to the top of the other resistors) to accomplish some of this tweaking. I don't think I made all the changes that were mentioned since it was working very well and I was tired of working on it.
If yours is an early one, maybe you need to review to see if there are any updates which you missed. I'm pretty sure that mine doesn't line up with the 0 tick mark when the VCA goes to zero (I can't remember which way it's offset).
But I also had a problem with my 110. Since the CV MOD pot has wires flown to it but has no solder lugs, kit builders had to bend the pins around the wires and add heat shrink around them for protection. I didn't have a heat shrink gun at the time and tried to melt the heat shrink by getting the tip of the soldering iron VERY close to the heat shrink. I ended up cooking the pot but not realizing it for a while since it worked well in most positions, but in some positions it had very strange symptoms.
You might want to look into that too.
John B.
2003-06-30 by groovyshaman@snet.net
> 6) How about trying it with a different VCA? A MOTM 190? The Minimoog?<snip>
> no problems
2003-06-30 by Paul Wagorn
>Ok, if you tried a different VCA and had "no problems", by this you meanthe
>click/pop went away, right? If so, it might be that the original 110 VCAis
>having some CV bleed-through and needs adjustment as described in theI tried that, it doesn't seems to help, unfortunately. (although i can make
>manual.
>The 110 may be clipping for some reason. If you put two different freqi'll try that out
>[preferably] sine waves into the RM section of the 110 "in question", does
>it experience any popping sounds?
>Another thought, do you have a mixer? Try attenuating the signals goinghmm, can't do that - i don't have something that will work with cv's :(
>into the VCA. Popping go away?
>Did you try Paul Schreiber's suggestion? Did it have any effect?no
>I'm curious, exactly what VCA did you use in place of the one 110 creatingminimoog
>the popping? A different 110? a 190? an external VCA?
>Grasping a bit, but how many modules are in your system, and what powerwell, my PS is full (it's a motm), but it should be ok....
>supply are you using?
where do I check for updates? mine is indeed an early one (i think!). I'll check that pot too....
2003-06-30 by Robert van der Kamp
> anyways, my post wasn't meant to be a complaint, moreDid you eliminate all other components in the chain, like
> "please someone help me make my motm make usable bass
> sounds"
2003-06-30 by osthelder
-----Original Message-----Hi Paul!
Sent: Monday, June 30, 2003 10:44 AM
Subject: [motm] Re: my clicking & popping bass notes
I know everyone has sent you good input, but here's another take on
this.
With very fast attack settings on low frequencies, I was hearing what
I thought was control voltage bleed through. I played with my
settings for quite a while, only to realize that the problem was my
VCA-based compressor! Softening the attack of the compressor was the
solution (while saving for a better one!). What are you plugged into?
Chub
