the new 190 bracket
the new 190 bracket
2003-01-21 by Chris Walcott
I just wanted to send some props to Paul and company.  The new bracket configuration for the 190 is brilliant!  It's 10 times easier to assemble everything  now.  And the manual has improved as well.  It's awesome to see how the kits have evolved in event he short time I've been building them.
MOTM Rules!
- chris
RE: the new 190 bracket
2003-01-21 by mate_stubb <mate_stubb@yahoo.com>
Props to Larry Hendry, who originally came up with the bracket idea
for Stooge panels because we couldn't use those imbedded studs. They
turned out to be versatile enough to use with pcbs that don't fit the
MOTM format (e.g. Blacet w/ pots mounted offboard) and also those
that do (Oakley and now MOTM).
Moe
Re: [motm] RE: the new 190 bracket
2003-01-21 by J. Larry Hendry
FYI to all who may not know:  I am the wholesale supplier to Paul on these
brackets. So, the conversion brackets I sell are the same ones you find on
your MOTM 190.  The beauty of the bracket (besides design) is cost.  These
brackets do trim cost from the other brackets and cost of panel studs which
translates into a little better cost / hence price on all MOTM modules that
use them.
I have 4 sizes available for retail sale at $4 each.  Here is the info:
http://www.wiseguysynth.com/larry/bracket.htm
Larry Hendry
To: <motm@yahoogroups.com>
Sent: Tuesday, January 21, 2003 2:22 PM
Subject: [motm] RE: the new 190 bracket
Moe
