PSU Mounting Ideas?
PSU Mounting Ideas?
2003-01-11 by inform3r
With rack space getting really limited I'm starting to think about
shoving the 900 PSU BEHIND the rack. The main issues I have questions about
are; where (and how) do I mount the toggle(power) switch? Anyone have any
experience with this? I'm not looking to do major surgery.
                John
ELECTRO:DISCO:RETRO:FUTURE
http://www.hongkongcounterfeit.com
Re: PSU Mounting Ideas?
2003-01-11 by r <datacult@yahoo.com>
about
questions about
have any
I have a question about this also.......
I have the PSU screwed into the 'wood' on the back of a wood
rack .......any danger of this thing starting a fire or burning the
wood?
about
questions about
have any
wood?
Re: [motm] PSU Mounting Ideas?
2003-01-11 by Jeffrey Pontius
Currently I have one of my motm 900's mounted on the back-rightside
(viewing from the front) in a 10" deep cabinet.  The 900 is mounted (using
the original holes in the 900) to steel shelving rails (the rails that are
attached to walls with snap-in shelf brackets), with the rails screwed
into 2 of the 4"X1" rear cabinet braces set off by 1/2" metal spacers.
*****You  should be careful though. If you cannot see the switch, ...
behind your  cabinet and need to 'feel around' to find the 900 switch,
then this setup is probably not a good idea.*****
[I think we need a 1U panel with switch and fuse (optionally, AC power
cord socket) for power units mounted internally to cabinets {I'm trying to
'encourage' someone in particular :-) }].
 Jeff
Re: [motm] Re: PSU Mounting Ideas?
2003-01-11 by John Blacet
If you are using one of those typical Power One supplies where the
chassis is the heat sink, you should not screw it down directly to a
wood cabinet. You need to have some air circulation around the chassis
if you ever want to use the PS near it's rated output. The best bet is
to use at least 1/2" spacers to elevate the PS off the wood case.
John Blacet
Blacet Research
http://www.blacet.com
2003-01-11 by Mike Marsh <mmarsh@websense.com>
I think I get plenty of circulation because my cabinets are open the
back.  I did not realize that the panel was the heat sink.  I've
never felt it be even mildy warm, though...
a
chassis
bet is
> Regards,
> John Blacet
> Blacet Research
2003-01-11 by J. Larry Hendry
I'll offer my $.02 (since I usually do). If you power supply is running hot
enough to ignite wood, it is overloaded.  Having said that, when I mounted
mine (on wood also), I mounted the regulators away from any contact with
wood.  They are on the inside back on this photo.
http://www.wiseguysynth.com/larry/cabinet/lower_open_09.jpg
wood?
2003-01-11 by mate_stubb <mate_stubb@yahoo.com>
The Synth of Doom mounts the PSUs upside down in the back using small
aluminum angle brackets, so that the mass of the aluminum chassis is
facing up instead of down to the wood:
http://www.hotrodmotm.com/images/case/synth_of_doom_back2.jpg
Moe
2003-01-11 by robert taylor
Does anyone know anything about this?
\ufffdThe RFE-901 is a 1U power supply control and stereo headphone amplifier.� This module provides a front-panel power switch for MOTM format synths as well as a stereo headphone amplifier for late-night playing.� There are LEDs to indicate presence of power supply voltages, as well as "Volume" and "Balance" controls to adjust the level and balance of the left and right audio inputs.� This module is NOT a power supply - it just controls the AC mains power to the power supply you already have!� A stooge panel design for this module exists and the first article is expected in September or October 2002.\ufffd
http://www.radio-flier.com/diy_corner.html
Robert
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
Frequency Determination?
2003-01-11 by Tentochi
Can any way give me a way to determine the frequency
of a VCO or LFO below 200 Hz?  I have a Fluke 87-III
and that is the slowest frequency it can detect.
Thanks!
Shemp
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
Re: [motm] Frequency Determination?
2003-01-12 by ixqy@aol.com
In a message dated 1/11/03 5:03:38 PM Central Standard Time,
tentochi2003@... writes:
 I think either a frequency counter or oscilloscope would be the most logical
choices. A freq. counter would be more precise, unless you got one of the
more expensive scopes with the readouts of frequencies, voltages, and what
not.
 I'm not really sure how accurate the handheld voltmeters with frequency
measurement are. I guess they'd be pretty accurate (?).
 Andrew
RE:Frequency Determination?
2003-01-12 by mate_stubb <mate_stubb@yahoo.com>
If your VCO is in the audio range and you can hear it, tune a second
VCO exactly one or more octaves higher until it gets into the range
that your meter can read. Then for each octave you added, halve the
freq reading.
Example: vco tuned two octaves up reads 440 Hz. Divide by two twice
to get 110 Hz.
Moe
2003-01-12 by J. Larry Hendry
It is a DIY Stooge panel made for a fellow MOTMer. GIF attached.  This panel
will be added to the public panel list and made available for purchase if
the PCB is made available.  I don't want to sell panels in advance of
knowing the module described is actually available in PCB form.
"The RFE-901 is a 1U power supply control and stereo headphone amplifier.
well as a stereo headphone amplifier for late-night playing.  There are LEDs
audio inputs.  This module is NOT a power supply - it just controls the AC
mains power to the power supply you already have!  A stooge panel design for
2002."
RE: [motm] PSU Mounting Ideas?
2003-01-13 by Chris Walcott
For what it's worth, my plan is to mount in the back and power on/off with a power strip switch. All my gear turns on that way anyway so it's no big deal for me to leave the rack on all the time.
- chris
Sent: Friday, January 10, 2003 10:52 PM
To: MOTM List
Subject: [motm] PSU Mounting Ideas?
