Re: [motm] JH thinks analogue/physical modelling
2002-11-06 by elhardt@att.net
Moe writes:
>>Are you (JH) thinking about tuned feedback/delay lines under voltage control
ala Ron Berry's stuff? Now THAT'S what would be the killer jewel in the MOTM
crown! I want several!!!<<
There are many pieces of gear floating around out there that already do this. I
have three different digital delays: Lexicon PCM-41, Deltalab Effectron, Roland
SDE-3000, and they all have voltage control of the delay time. In addition the
Roland brings the feedback loop to the outside world so you can patch in
whatever you want, such as filter dampening. I just pulled my SDE out of the
rack two days ago in preparation to see how well I can get it to track the
keyboard. So look around at your current gear and you might already have
something that does this.
Also since I'm in the middle of my research to make another push forward in
synthetic violin/cello realism, I've also searched around for out the ordinary
software that might aid in realistic acoustic modelling. Here's a couple of
interesting ones:
1) "Spectral Delay" by Native Instruments. I've downloaded the demo and played
around with it. If you want the most sophisticated formant filtering around,
this will do it in realtime with any audio input. You can adjust the levels of
160 frequency bands across the audio spectrum from zero to full volume. You can
mimic the sound of just about any resonant body with this. I've been
considering buying it just for this feature alone.
2) "Tera" by VirSyn. This is a software virtual analog synth, but with extra
stuff there for physical modelling. It includes a controllable delay line
specifically for physical modelling. It also has two 128 pole filters that
allow you to draw complex formants right on screen, and you can morph between
the two if you want. Even beyond this there is a three band parametric formant
filter.
3) "Tassman" by Applied Acoustics. Also a software virtual analog synth with
extras for physical modelling. It's been around for a little while.
And as long as we're on the subject, the latest Keyboard magazine gave a tip on
how to make a parametric EQ pluggin act like a wah-wah pedal, but this same tip
can basically turn any parametric EQ into a parametric formant filter much like
Polyfusions old module. This could be more useful than a fixed filter for some
things. Tip: Using a stereo parametric EQ, split a signal and run it through
both halves, then invert the output of one channel and mix the two together.
Now raise the bands you want on just one channel (and set band freqs and width
too) and you will only hear the audio from those bands, because the inverting
process will cancel out all other audio. I tried it with an analog parametric
EQ and it works quite well. It gives you much more extreme tone shaping than
using a parametric EQ hooked up in a conventional way.
-Elhardt
2002-11-06 by Les Mizzell
>>voltage control ala Ron Berry's stuff?
I have a Modcan VC Delay on order mainly to experiment with some of
Ron's techniques. The Modcan has a short enough delay time to do this,
and all parameters are under voltage contro.  Will post a review once I
get my unit and have had a few days to try some things...
2002-11-07 by mate_stubb
It takes two things to 'play scales' with a VC delay line - one is
sufficiently short delay time capability, but equally important is
the delay time resolution. I haven't been able to play with this
stuff myself, but I wouldn't be surprised if you had to vary the
delay time in sub-millisecond increments between notes.
Good luck with your experiment!
Moe
this,
I
2002-11-07 by jhaible
this. I
Roland
Maybe I shouldn't write too much about this at the moment - not before
I've read all the interesting links (thanks for the links!). And I'm not
thru
with reading the Yamaha patents yet.
But really, a VC delay line is only one tiny portion of the whole thing.
I have done experiments with VC delay lines in the past, but they sound
like a comb filter, not like a flute of a saxophone.
JH.
RE: [motm] JH thinks analogue/physical modelling
2002-11-07 by John Loffink
Moe's exactly right on this one.  You need very precise resolution and
short delay times for physical modeling, something not likely provided
by the VC digital delays.  That still doesn't mean they can't be fun for
other reasons though.
John Loffink
jloffink@...
> -----Original Message-----
> From: mate_stubb [mailto:mate_stubb@...]
> Sent: Wednesday, November 06, 2002 7:26 PM
> To: motm@yahoogroups.com
> Subject: Re: [motm] JH thinks analogue/physical modelling
> Moe
Re: JH thinks analogue/physical modelling
2002-11-07 by Mike Marsh
Will Blacet's Time Machine work?  Short delays, VC, regen...
of
this,
once I
2002-11-08 by elhardt@att.net
JH writes:
>>But really, a VC delay line is only one tiny portion of the whole thing. I
have done experiments with VC delay lines in the past, but they sound like a
comb filter, not like a flute of a saxophone.<<
They are good for plucked string type sounds though. A couple of us have tried
it on the Nord Modular but couldn't get the delay module to track the keyboard.
The plucked string sounds were quite realistic but unplayable. I figured maybe
a sampler would help. A person could tune the delay on a note by note basis and
sample each one, then play the final sound back on a sampler.
John Loffink writes:
other reasons though.<<
That's why some things are better done completely in the digital domain. That's
why I listed some useful software geared toward this.
BTW, I found out that Yamaha has something called Poly-VL. It's their VL series
of physical modeling done in software that runs polyphonically on a Pentium III
based computer. The problem is it doesn't appear to be available in the US.
-Elhardt
2002-11-08 by jhaible
tried
keyboard.
maybe
basis and
You're loosing all the fun of performance parameters then ...
That's
I don't worry about the resolution of a VC delay. Really.
The fact that most delays are not built to handle fine resolution (why
should they?)
doesn't mean it's impossible (or even difficult) to make them.
Tracking is a problem, expecially if you leave the case of a pure delay
loop,
but then again this could be solved with an autotune routine which
calibrates
a CV conversion table once the model is set up.
Pro digital: can handle much more parameters easily
Pro analogue: more intuitive, less aliasing problems
series
Pentium III
US.
I didn't know that! So maybe now I don't have to buy 3 VL1m's to expand
my VL7 for 7-note polyphony ?!
JH.
2002-11-08 by John Loffink
I think we're all somewhat in agreement here, but just to clarify, I was
referring specifically to the units that were named: Lexicon PCM-41,
Deltalab Effectron, Roland SDE-3000. I doubt these have the resolution
for physical modeling.  On the other hand, it's certainly possible to
design a digital delay with the fine resolution needed, I've just never
seen anyone do it.
> should they?)
delay
> loop,
> calibrates
We're straying a little off topic here, but just to clarify, one of the
weaknesses of the Nord Modular is that its integer parameter values will
also limit the resolution.  If working in the digital domain I would
recommend something like Native Instruments' Reaktor which uses floating
point values throughout, giving fine resolution where needed.
have
> tried it on the Nord Modular but couldn't get the delay module to
track
> the keyboard. The plucked string sounds were quite realistic but
> unplayable. I figured maybe a sampler would help. A person could tune
> delay on a note by note basis and sample each one, then play the final
John Loffink
jloffink@...
2002-11-08 by Tentochi
A couple of links for the Poly-VL and a link for
d/ling.
--Shemp
http://www.yamaha.co.jp/english/news/99021802.html
http://www.harmony-central.com/Newp/1999/SoftSynthesizer-Poly-VL.html
S-YXG100\ufffd{PolyVL
S-YXG100 PVLVersion:1.11.46
Download the software here (I haven't tried it, it is
in Japanese):
http://www.yamaha.co.jp/xg/download/s-synth/download.html
Plug-In Board:
http://www.yamaha-music.co.uk/products/sections/PLG150VL.asp?sectionid=76
Do you Yahoo!?
U2 on LAUNCH - Exclusive greatest hits videos
http://launch.yahoo.com/u2
2002-11-08 by Simon
>their VL series
>Pentium III
Maybe it is available from the US Sage distributor?
Is this poly-VL thing for real, any info available, or are we just
waiting for the screenshots to be faked in Photoshop.
Simon
Canberra
AUSTRALIA
Simon writes:
>>Maybe it is available from the US Sage distributor? Is this poly-VL thing for
real, any info available, or are we just waiting for the screenshots to be
faked in Photoshop.<<
Yes it's real and just a post or two up Tentochi gave some links. The problem
is it appears to have only been released in Japan, with Japanese documentation
and pricing. Only one or two US/UK press releases let me know it existed in the
first place.
JH writes:
>>You're loosing all the fun of performance parameters then.<<
For plucked string sounds a sampler has many performance parameters to alter
and expressively play a sample. For wind instruments, that's another story.
>>I didn't know that! So maybe now I don't have to buy 3 VL1m's to expand my
VL7 for 7-note polyphony ?!<<
You could sell what you have and get Poly-VL which I think can do 8 voices.
Maybe the polyphony isn't needed, but for those of us who bought too late to
get the dual operator VL1 (or whatever they call it), I'm thinking the Poly-VL
might be a good alternative and run the more advanced patches I've heard.
That's if you don't mind having to use a computer.
point values throughout, giving fine resolution where needed.<<
Yes, it is the Nord's integer intervals that didn't allow keyboard tracking if
I remember correctly. To get around some of the Nord Mod limitations including
delay memory and total module count I've already bought Reaktor.
-Elhardt
2002-11-09 by Simon
>poly-VL thing for
>existed in the
>first place.
Is it a recent product, and still available?
Is it software only, is there any hardware to go inside the PC?
What does it sell for in Japan?
Simon
Canberra
AUSTRALIA
2002-11-09 by Simon
Checked them already. But really, I only asked 3 simple questions
which could have been answered with as much effort as it took for you
to tell me to check the links again, to look for information that
doesn't seem to be there!
It wasn't clear to me exactly what the Poly-VL was, what the Yamaha
SoftSynthesizer was, whether actual hardware was required, if so what
that hardware actually was, etc. I couldn't find any information on
pricing and current availability.
It seems that it maybe needs some sort of Yamaha SoftSynthesizer
soundcard or sound module that has a connector for the Poly-VL plugin
board. Just doesn't seem to be a software solution, as I was
expecting, but more a hardware solution that uses the host CPU for
extra DSP power.
Info says it was released in February 1999, but I didn't notice if it
is still available, and what a current price would be.
Maybe someone has checked the current pricing and availability, and
can let us know if it is still available in Japan and what it costs.
Simon
Canberra
AUSTRALIA
>Simon--
>As John said, everything is in the links I posted.
>Check them out.
>Cheers!
>Todd
>>  >poly-VL thing for
>>  let me know it
>>  >existed in the
>>  >first place.
>>  inside the PC?
>>  Thanks,
>>  Simon
>>  Canberra
>>  AUSTRALIA
>>  Your use of Yahoo! Groups is subject to
>>  http://docs.yahoo.com/info/terms/
>Do you Yahoo!?
2002-11-09 by elhardt@att.net
Simon writes:
SoftSynthesizer was, whether actual hardware was required, if so what that
hardware actually was, etc. I couldn't find any information on pricing and
current availability. It seems that it maybe needs some sort of Yamaha
SoftSynthesizer soundcard or sound module that has a connector for the Poly-VL
plugin board. Just doesn't seem to be a software solution, as I was expecting,
but more a hardware solution that uses the host CPU for extra DSP power.<<
I tried to search some Japanese sites for pricing a couple of weeks ago, but
not being able to read Japanese, I wasn't able to navigate to a price. I was
also a bit confused as to whether it was software only. But from what I read it
sounded as if it was a software only solution. The following quotes from the
press release seem to support that.
"Yamaha SoftSynthesizer embodies software technology that enables the playback
of MIDI data even without dedicated hardware such as an external tone generator
or a sound card."
"The Poly-VL, a plug-in module for the SoftSynthesizer S-YXG100" (if it's a
module for a software based synth, it should be a software plug-in much like a
VST plug-in)
"is designed to take advantage of the performance of Intel\ufffd s Pentium\ufffd III
processor." (since it needs the power of a Pentium III's parallel floating
point unit, it's most likely not hardware based)
-Elhardt
OT: Yamaha Poly-VL
2002-11-09 by Simon
>Simon writes:
>what I read it
>tone generator
>or a sound card."
>VST plug-in)
>"is designed to take advantage of the performance of Intel’ s Pentium® III
But, Todd calls it a 'board' in describing this link, and on the page
it is called a 'PLG Card'...
>Plug-In Board:
...this seems to be a plugin pcb for the SW1000XG PCI Audio MIDI
Board, and XG PLG compatible synths, the system is discussed here...
http://www.yamahasynth.com/pro/plg150/ms.html
The SW1000XG is described here...
http://www.xgfactory.com/
Then on this link...
...it says that the Poly_VL is a plugin module for the
SoftSynthesizer S-YXG100 To me, module means hardware/pcb module that
connects as a Daughterboard to a sound card. It also mentions the
SoftSynthesizer S-YXG50, but doesn't specifically say that this works
with the Poly-VL plugin module.
So, it seems that Todd has provded links to two different products,
one being a plugin Poly-VL pcb for the SW1000XG soundcard, the other
being a possible software plugin for a possible softsynth called the
S-YXG100.
I can't read Japanese, so I can't find out much more.
Simon
Canberra
AUSTRALIA
Re: [motm] OT: Yamaha Poly-VL (S-YXG100plus/Sondius XG)
2002-11-09 by Simon
Some of the different names/model numbers for it...
S-YXG100 Plus
S-YXG100+VL
Sondious XG
Some info in English...
http://www.yamaha.co.uk/xg/html/midplug/m_mid9.htm
http://www.yamaha.co.uk/xg/html/midplug/m_sond4.htm
http://www.liveupdate.com/yamahapress.html
Says it is based on the VL70m, is this much the same as the VL7?
Still not clear if the files on the Japanese site are a free full
version, or just a demo/trial.
I can't try them out as I am on a Mac.
Seems to be pretty high latency, 400MS, but can be tuned down to 80MS
with the correct drivers.
Might be interesting to dedicate an older laptop to it.
Simon
Canberra
AUSTRALIA
2002-11-09 by Simon
>S-YXG100 Plus
>S-YXG100+VL
>Sondious XG
That should be Sondius XG.
Here it is for sale...
http://www.digitalmusicworld.com/superstore/product.asp?pf%5Fid=2582&CT=&mscssid=DK6DNDFA026G8K6XSG1HA6167222EBGA
Says that after payment you receive a keydisk program to unlock the
downloaded trial version to a full version.
So I guess that the available downloads are for the trial/demo version.
I would be interested to read a review if someone wants to try it out.
Simon
Canberra
AUSTRALIA
2002-11-10 by alt-mode
Another interesting Physical Modelling system is the Korg OASYS PCI
card.  There are some very nice PM modules that have been created and you
can download the "synthkit" development tool and create your own on the
Mac.  The downside is that the cards are no longer made and the OS support
stopped with Windows ME and MacOS 9.x.  The OASYS doesn't have lots of
polyphony but it has outstanding sound quality.
         Eric
At 03:56 PM 11/9/02 +1000, Simon wrote:
> >Simon writes:
> Poly-VL
> expecting,
> >what I read it
> playback
> >tone generator
> >or a sound card."
> like a
> >VST plug-in)
> >Plug-In Board:
>S-YXG100.
>Simon
>Canberra
>AUSTRALIA
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2002-11-11 by elhardt@att.net
Simon writes:
it is called a 'PLG Card'...Plug-In Board: http://www.yamaha-
music.co.uk/products/sections/PLG150VL.asp?sectionid=76<<
I'll have to visit the links you've posted, but don't forget Yamaha makes other
products, such as a hardware VL board for a number of their hardware
synthesizers and keyboards. Without confirming this, I think that's what the
PLG150VL is.
>>Says it is based on the VL70m, is this much the same as the VL7?<<
The VL70m is a small half rack size module, and the VL7 is a keyboard. I
believe they are the same functionally. The VL1 is a duophonic VL7. However I
seem to remember Yamaha adding a new resonator type to the VL1 or VL7 that the
VL70m didn't have. The're still all basically the same thing though.
>>So I guess that the available downloads are for the trial/demo version.<<
Since it isn't available in the US I'm assuming the software is probably all in
Japanese and would be little use to us english speaking people.
-Elhardt
2002-11-11 by Simon
>probably all in
No...if you can translate UK english into US english, there is a 30
day demo on the UK Yamaha site, as Sondius XG...
SYXG100  XG & VL PHYSICAL MODELING SOFTWARE SYNTH (ALSO INCLUDES THE
NEW V4.0 PLAYER)
S-YXG100 (Sondius XG) combines the World beating S-YXG50 software XG
engine with the already legendary  SVA physical modeling techniques
used by Yamaha's ground breaking VL1, VL7 and VL70m tone generators.
(Win95/98/ME, Updated 26/07/2001)
Simon
Canberra
AUSTRALIA
2002-11-11 by Simon
>Simon writes:
><http://www.yamaha->http://www.yamaha-
>makes other
>PLG150VL is.
Yes, this is a hardware expander board for synths as well as the
SW1000XG sound card.
Kenton makes a rack box to hold four of these cards, it can be used
to expand an SW1000XG sound card, or can be bought with an 8 output
card to allow standalone operation...
http://www.kentonuk.com/productspecs/plugstation.html
So, you could have four of these boards running in a 1U rack mount
box, with stereo outputs from each module.
PLG cards currently available from Yamaha
PLG150AN Analogue Physical Modelling card
PLG150VL Virtual Acoustic Modelling card
PLG150PF Acclaimed award winning Piano card with sounds taken from
Yamaha's flagship electric piano range
PLG150DX FM synthesis card based on the legendary DX7
PLG100VH DSP3 based (same DSP technology as used on the Yamaha 02Ri
digital mixer) vocal harmoniser and effects board
Simon
Canberra
AUSTRALIA
