Pots
Pots
2002-10-29 by dave_oleksy
Hello all,
  I was just wondering when you would choose to use a spectrol 149
series pot over the bournes pots. Thanks
dave
Re: [motm] Pots
2002-10-29 by Paul Schreiber
Several reasons:
a) the Spectrol are available in cermet (149 series). These are more temperature stable than
conductive plastic. Also, when I was first looking at pot choices, Bourns were custom ordered
(still are!) with a staggering 18 WEEKs lead time (shortened to 14 now).
b) The Spectrol pots I could order from Mouser in small quantities.
To: <motm@yahoogroups.com>
Sent: Tuesday, October 29, 2002 1:14 PM
Subject: [motm] Pots
> Hello all,
> dave
Re: Pots
2002-10-29 by strohs56k
--- In motm@y..., "Paul Schreiber" <synth1@a...> wrote:
> Several reasons:
> more temperature stable than conductive plastic. Also, when I was
> first looking at pot choices, Bourns were custom ordered (still
OK - to add something to this question: I assume the Spectrol pots
are available in both cermet and conductive plastic?  If so, why not
(for example) use only the Spectrol pots?
I am mostly curious due to the recent discussion on AH - the Bourns
and Spectrol pots certainly feel different.  I think I prefer the feel
of the Bourns pots (as someone said - they are very "silky", like the
faders on an audio console.) The Spectrol 149 pots seem much more
damped (more resistance) and the Spectrol 248? even more so.
Personally, I don't think I like the "damped" feel as much - but what
is really odd is going between the Spectrol and Bourns is like a night
and day difference.  Seems like it would be preferable to have a
consistent feel?
Seth
Re: [motm] Pots
2002-10-29 by Tentochi
Paul--
Are you saying in general, you would have used all
Bournes parts if they would have been feasible and
readily available????
--Shemp
> small quantities.
Do you Yahoo!?
HotJobs - Search new jobs daily now
http://hotjobs.yahoo.com/
Re: [motm] Pots
I offer replacement pots (both Spectrol and Bourns) for $6.50ea. And, if you need a manual for a
purchased module(s),  send me an email.
Re: [motm] Pots
2002-10-29 by mate_stubb
To expand on Paul's answer:
You would use a cermet pot (149) in your coarse and fine tuning VCO
controls (if you want it as stable as possible, that is).
Moe
Several reasons:
Bourns were
custom ordered
now).
> Hello all,
> dave
Re: Pots (the full story)
2002-10-30 by strohs56k
> And, if you need a manual for a purchased module, send me an
> email.  [...]
Some of you are probably confused by this response and are thinking,
buy replacement pots? Huh? And as you might expect, there is a little
more to this story!
Right after posting the "why not just use one brand" question, I
called Paul expecting to ask a completely different question.
However, "Spectrol vs Bourns" still seemed to be on his mind - so here
is my summary of potentiometers 101:
There are essentially two base technologies: cermet and conductive
plastic.  (This refers to the type of electrically resistive element
used inside the potentiometer.)  Conductive plastic has the longest
life so, all else being equal, it is the technology of choice!
However, all else is almost never equal.  Cermet offers significantly
lower electrical noise (Paul claims 10x) and, as such, it is preferred
in a few critical applications such as tuning the frequency of an
oscillator or filter.  (But you already knew this based on other posts
to this thread.)
So, why choose one *brand* over the other?  Here are the details:
Spectrol offers conductive plastic elements (148 series) and cermet
elements (149 series) in an otherwise equal form factor.  These
Spectrol pots are only available with PC board "pins" - that is,
intended to mount directly to a printed circuit board.  The standard
Spectrol 148 and 149 series pots are linear taper.  Log taper is only
available by special order and you must commit to quantity.
Bourns only offers conductive plastic elements.  Bourns pots are
available with PC board "pins" AND with solder tabs for termination to
wire.  Bourns pots are always "special order" (no distributor stock)
but are available in both linear and log taper configurations.
The form factor (specifically, the distance from the centerline of the
shaft to the base of the pot) is different between the Spectrol and
Bourns pots and, as such, it is not possible to mix and match the two
brands of pots on the same printed circuit.
So as it turns out, there does seem to be valid reasons why you might
choose one brand over the other based on the requirements of a
particular module.  (A specific example from Paul - EGs need large
value log taper pots and it is expected that these pots will get a lot
of use.  In this case, Bourns is the preferred solution as these are
the long life conductive plastic and log taper is available as a
standard configuration.  Sure enough, there are board mounted Bourns
pots in the 800 EG!  In other modules where there is a mix of cermet
and conductive plastic types mounted to the circuit board, the
Spectrol types are used.)
Fine - but you are probably still wondering about the replacement pot
comment?  Notice in my original question that I mention the Spectrol
248 series - specifically, that I found the 248 series to be
particularly stiff.  Wait a minute, what is the 248 series???  Well,
it turns out that very early on (before Paul managed to convince
Spectrol to build 148 series 100k log pots) some modules were built
with this 248 series.  This Spectrol 248 series has a plastic busing
around the shaft where all the other types have a metal busing -
logically, this explains the difference in feel.  The 148 and 248 seem
to be interchangeable otherwise.
Because the 148 series log pots are special order, I asked Paul if I
could purchase a few of these from him should I decide that I really
can't stand the feel of the 248 series.  He agreed, which I think is
pretty damn nice of him!
Paul also agreed to provide me with a copy of the MOTM 300 assembly /
calibration / operation manual - which was the real reason that I
called him.  My MOTM setup doesn't have any VCOs yet and, as Cuari has
put his MOTM system up for sale, I offered to buy a bunch of VCOs from
him.  (He didn't have the module documentation - and I wanted to be
sure I could get a copy just in case.)  So, now that I have some
VCOs on the way I can really make some noise!  Oh wait, I still need
to work on that patch cable deficiency... ;)
Seth
2002-10-30 by robert taylor
>more to this story!
Even more to the story:
I purchased several modules listed for sale from group members this last month.� Two boxes were well packaged (thanks Aaron Swihart and Cuari7!).� One box arrived with much less bubble pack, and the plates the PCB's mount to were folded in towards the front panels (which bent some pot shafts).� Hencs,I e-mailed Paul about getting replacement pots in the midst of the pot discussion.�
He answered both personaly and to the list.�
And quickly.�
For modules I hadn't even bought from him.�
Another impressed customer,
robert
Get faster connections\ufffd-- switch to\ufffdMSN Internet Access! Click Here
The Death of Kenton???
2002-10-30 by Tentochi
Kenton has discontinued the Pro-4 and is no longer
doing retrofits.  Are they winding down business
altogether?  What gives?
Below is a little article from Future Music.
--Shemp
September 12, 2002
Kenton discontinues retrofit kits, your last chance to
retrofit....
After 16 years of supplying MIDI retrofits for most of
the popular pre-MIDI analogue synthesisers, Kenton are
to discontinue the production of the retrofit kits
when the current stocks of circuit boards and
components have been exhausted. For most models this
is expected to be at the end of this year, although
some models have gone already. If you have been
postponing getting your synth retrofitted, this is
your last chance as the retrofit kits will disappear
from the Kenton price list when the 2003 list is made.
Kenton's range of socket kits is unaffected by this
announcement.
For more information please call freephone
08000-KENTON (08000-536866) or email
sales@....
Do you Yahoo!?
[OT] [ANC] The Radiophonic Workshop CD
2002-10-31 by Tentochi
The BBC Radiophonic Workshop has just released
(November 26, 2002 in the US) a CD (also available on
vinyl) containing highlights of some of their more
experimental sounds.  It looks like it should be worth
checking out.
     http://www.amazon.com/exec/obidos/ASIN/B00006L9TM
In the UK:
http://www.amazon.co.uk/exec/obidos/ASIN/B00006L9TM
Some very good info on the BBC Radiophonic Workshop
can be found here:
http://www.glias.org.uk/glias/rws/pgs/a_toc.htm
Track Listing----
 1. La Grande Piece de la Foire de la Rue Delaware -
Malcolm Clarke
 2. Brio - John Baker
 3. Adagio - Dick Mills
 4. Geraldine - Roger Limb
 5. Bath Time - Malcolm Clarke
 6. Nenuphar - Glynis Jones/Malcolm Clarke
 7. Accentric - John Baker
 8. Major Bloodnok's Stomach - Dick Mills
 9. The Panel Beaters - Paddy Kingsland
10. Crazy Dazy - Dick Mills
11. Veils and Mirrors - Glynis Jones
12. Romanescan Rout - Malcolm Clarke
13. Schlum Rooli - Glynis Jones
14. Kitten's Lullaby - Roger Limb
15. Chino - John Baker
16. Waltz Antipathy - Richard Yeoman-Clark
17. The World of Science - Paddy Kingsland
--Shemp (aka "The Panel Beater")
Do you Yahoo!?
