Functional density - or what to do while waiting for your MOTM modules
2002-08-18 by pugix
While awaiting arrival of my MOTM modules, I've been meditating on
functional density in modular synthesizers.  I've always operated on
a feeling about how much tonal richness I could get from a set of
modules, which had to do roughly with the quantity of activity going
on all at once.  This is directly related to the number of distinct
signals available.  The richness also has to do with the number of
voltage-controlled parameters that are being modulated
simultaneously.
I came up with a simple way to quantify the functional density of a
module as follows.  It is the number of distinct signal sources
produced by a module plus the number of independently variable
voltage-controlled parameters afforded by the module, divided by the
panel width.  Here's the breakdown for MOTM.
MOTM    MODULE  SOURCES PARAMS  WIDTH   DENSITY
101     S&H     2       0       2       1
120     SUB     0       0       2       0
190     VCA     0       2       1       2
300     VCO     1       2       2       1.5
310     VCO     1       2       1       3
320     LFO     1       2       2       1.5
380     LFO     4       0       1       4
390     LFO     2       1       1       3
410     VCF     2       3       2       2.5
410     VCF+OMS 2       6       3       2.66
420     VCF     0       1       2       0.5
440     VCF     0       2       2       1
480     VCF     0       2       2       1
490     VCF     0       1       1       1
700     ROUTER  0       2       2       1
800     EG      0       0       1       0
820     LAG     0       2       2       1
830     MIX     0       0       2       0
850     PEDAL   0       0       1       0
890     MIX     0       0       1       0
My rational for counting sources: The 101 S&H has one noise source,
plus one clock.  Even though filters can oscillate, I'm not counting
that as a source.  I don't count multiple waveforms coming from the
same oscillator.
Most of this is not too surprising.  The quad LFO in a 1U panel has a
high functional density.  Modules that do static processing, such as
envelope generators and mixers have zero density, which means that
when added to a system simply lower the overall density.  To me that
gives them a lower value.  But then I seem to be obsessed with
functional density!
This analysis did produce a few interesting results.  The 310 micro
VCO has twice the functional density as its big brother, the 300,
because it has the same number of sources (1) and parameters (FM and
PWM), but in half the space.  That's the idea, I suppose.
The 410 Triple Resonant Filter has a high functional density due to
the internal dual LFO, which adds two sources.  The 410 also has
three independent parameters: combined filter frequency (sweep), LFO
rate, LFO internal modulation depth.  Let's add the OMS-410.  Now
there are six parameters: 3 independent filter frequency controls,
LFO rate, internal LFO depth, external LFO depth.  This is based on
the MOTM-standard option panel for the OMS-410.  But wait.  Now it's
3U wide.  Doing the math shows that adding the OMS-410 increased the
functional density only a tad from 2.5 to 2.66.  But I like getting
those extra three parameters to control.  Notice that this analysis
does not quantify the aspect of having the LFO outputs available
externally.  Making the LFOs available for input to other processing
does not add any new sources to the system.
MY WISH LIST (Hey Paul!)
Being an old Serge guy, I long for the Serge dual slewing module.
Now, if Paul would make a very minor modification to the 820 Lag
Processor we would have this.  Put a comparator with big hysteresis
on the output, so that when the output level reaches maximum (+5v)
the comparator puts out a -6v.  Now the comparator will stay at -6v
until the output goes all the way down to -5v, at which point it
snaps back to +6v again.  So what, you say?  Well, now you now have a
pulse output.  Patch that output into the lag input and now you have
an LFO with a voltage-controllable waveshape.  Functional density
goes up to 1.5.  But even better, I would like to see a micro Lag
Processor/LFO, fitting into a 1U panel with six jacks and three
pots.
Jacks:  Input, Pulse Out, Lag Out, VC Up, VC Down, VC Up-Down
Pots:   Initial Up, Initial Down, +/- Inverting attenuator VC Up-Down
input
Sources 1, Parameters 2, Width 1, Functional density 3.
I had about eight or so modules of different variants on this theme
in my original synthesizer (which is now probably gathering dust in
somebody's attic).
-Richard Brewster
Re: [motm] Functional density - or what to do while waiting for your MOTM modules
2002-08-18 by jhaible
> pots.
This is a good idea, but what about this: A sparate module with all kind
of auxiliary modules, comparators, inverters, logic functions. Then you
can route the VCLAG to a comparator, but you can also connect the ADSR
this way (only guessing here). And you could use the comparator for
other functions, like keyboard split, for triggering a ADSR from an
amplified audio signal, and so on.
I would provide multiple jacks on the auxiliary module then (like, the
comparator having two input jacks in parallel), because you will
most likely use it together with another module.
JH.
2002-08-18 by Richard Brewster
You are talking about micro modules.  The problem with them is they usually
have zero functional density.  Comparators, inverters, attenuators, mixers,
and so forth do not originate any signals, nor do they ordinarily have
voltage-controllable parameters.  So unless you have a large studio with a
lot of panel space to spare, it's better to integrate these processors into
other modules, just like you see in most MOTM modules.
Here is an example of extremely high functional density.  I once built an
Electronotes "multiphase waveform animator."  This module had only two panel
jacks, in and out.  The input was a sawtooth wave.  Nine internal mutually
detuned fixed-frequency VCOs drove nine parallel phase shifters, and all the
outputs were mixed.  This produced an incredibly rich and active timbre that
perfectly tracked the input frequency.  The functional density was 9.  For
two jacks of panel space there were 9 independent signal sources.  The
animator offered no voltage-controlled parameters at all.  Hmm...
Actually, there were the nine phase shifters, too.  So maybe this could be
considered 18 density!  That really was an amazing module.
I may need to rethink the quantification of a controllable parameter to
include internally controlled ones, such as the 410 VCF.  It has three
filters, each having VC frequency controlled by internal VCOs.  This is
similar to what I just described.  By this criterion, I'd have to increase
the number of controllable parameters for the 410 from 3 to 5.  Coming full
circle, here is an argument for just the opposite of micro modules.  What if
more modules contained internal LFOs?
Whatever direction these design considerations go would skew the resulting
music in certain directions.  It would be a different sort of sound that
contained, say dozens of LFOs whirring, as opposed, say to dozens of
sequencers.  What it comes down to is that we as musicians will tend to
select the kinds of modules that get us closer to the sounds we like.  And
the less we know in advance what we will like, the more and varied modules
we will want!
Richard
To: <motm@yahoogroups.com>; "pugix" <pugix@...>
Sent: Sunday, August 18, 2002 10:55 AM
Subject: Re: [motm] Functional density - or what to do while waiting for
your MOTM modules
> > pots.
> JH.
Re: Functional density - or what to do while waiting for your MOTM modules
2002-08-18 by mmarsh100
I wonder if this is a West Coast vs East Coast thing?  Moog vs
Buchla (or Serge for that matter).  MOTM is East coast with each
module dedicated (more or less) to a single function.  So if I
understand correctly, each MOTM module would have low desity.  I
like it that way, but that's just me.
Jurgen's idea for a utility module is very welcome.  I have long
wanted something like this for my MOTM.
Mike
they usually
have
studio with a
processors into
built an
two panel
mutually
and all the
timbre that
9.  For
The
could be
parameter to
three
This is
increase
Coming full
modules.  What if
resulting
sound that
of
tend to
like.  And
modules
> we will want!
> Richard
> From: "jhaible" <jhaible@d...>
> To: <motm@y...>; "pugix" <pugix@n...>
waiting for
> your MOTM modules
module.
Lag
hysteresis
(+5v)
at -6v
it
have a
you have
density
Lag
> > > pots.
all kind
Then you
the ADSR
for
an
(like, the
> > JH.
2002-08-18 by Paul Schreiber
[[taking a quick break]]
a) I'm considering doing the Electronotes MPWA design (MOTM-ized) for next year. I want to hear
audio examples first if possible. Anyone? I built one in like 1980 but I can't recall it's "cool"
factor.
b) Welcome to the gut-knotting world of system archetecture :) It's a problem I struggle with all
the time.
Is it "better" to crank out 4 or 5 1U wide, easy-to-build (therefore, easy for me to KIT) modules
or have a SuperWoggleGonkulator?
There is no easy answer. But it doesn't mean we can't debate it. That is what this forum is for.
We leave the immature sniping to other groups and discuss reality here.
OK, back to a 64oz Dr. Pepper, Pat Methney on the CD and lots of little plastic bags.....
<Paul S>
b) Well, one does not preclude the other!
I would not mind having the 500 series available :) East Coast or
West Coast or in between, it's all musical!
Mike
> factor.
> the time.
here.
> <Paul S>
2002-08-19 by Richard Brewster
> factor.
As part of my getting back into synthesizers after a 20-year hiatus, I will
be putting all of my tape recordings onto CD.  I have *lots* of examples of
the MPWA!  Combined with a wonderful Electronotes 4-pole LPF it produced
what I called "the voice of God".  I will be glad to provide samples when I
get there.  It may be a few weeks.  I am rebuilding an older Windows 98 PC
to set it up just for this task.
Richard
2002-08-19 by mmarsh100
I am but an ignorant laborer.  Please indulge my lack of education:
what is MPWA?
Mike
ized) for next
1980 but I
> > factor.
hiatus, I will
examples of
produced
samples when I
Windows 98 PC
> Richard
2002-08-19 by Tony Allgood
This is an interesting idea, but I think the list would need another
column if I were looking at the whole aspect of module usage. Perhaps
'functional outputs' or something. Rating the Sub-oct-mux as zero
appears to be missing the whole point of the module.
> Doing the math shows that adding the OMS-410 increased the functional
Yes, but the 'density' list allows internal modulators to be counted as
sources. The MOTM-410s LFOs are not accesible as separate entities. One
of the requests that people made on the Oakley group was to make these
available to the front panel. Hence the use of the OMS-410. I actually
end up using the 410's LFOs for all sorts of other things too.
Advert time: You may want to take a look at the OMS-820 with MOTM-820
combination. And it has four pretty LEDs that flash very nicely.
Tony
I totally agree.  My quantifications of functionality are too simplistic.
There should be a third factor that quantifies functionality other than by
the number of independent signals and the number of independent controllable
parameters.  Please don't take my simple idea too seriously.
I looked at the OMS-820, and it did remind me of the Serge slewing module.
Great idea, Tony!
-Richard
Re: [motm] Re: Functional density - or what to do while waiting for your MOTM modules
2002-08-20 by nathan durham
(therefore, easy for me to KIT) modules or have a SuperWoggleGonkulator?
Actually, given Paul's hectic schedule, one probably does preclude the
other. In this case, I'd rather have more modules with individual
functions than one with everything.
nathan
