Variable waveshape from a 300
2002-05-11 by George Kisslak
BTW, a way to support variable waveshaping from a 300: put two different
waveforms from the 300 into two separate 110s.  Put a 320 triangle into a
mult.  Out of the mult into one 110, and out of the mult into an inverter
(you have one of these, right?) into the other 110.  Then out of the two
110s into an 830 mixer.  Like fading from one waveform to the other.  If you
don't need to fade, use a 700 instead of the two 110s.
Man... yet ANOTHER use for the upcoming 130.  ;^)
George - praying for the release of this module!
