MOTM-450 layout
2002-04-12 by J. Larry Hendry
Well since almost everyone else has spoken their piece on this, I will enter mine. 1. Actually, any layout is fine, as most have said, it is about the sound. Having said that, I do have some preferences. 2. I do not like the knobs that are so low on the panel. I guess I would not mind so much if the panel was crammed full. But, it is not. I would prefer that no knob is lower than what can have at least one jack under it. I would rather use some of the space "off board" space where the EQ I/O switch is for a couple of the knobs / controls. 3. Since the Low and High controls are different (more shelving) and I understand it, they are the two that make sense to move into Column 3. One in row 1 and one in row 4. The space between Low and High can have switch and LED. 4. I like keeping pots on the board. But having only 2 of 10 off the board does not seem bad to me. Larry Hendry
