MOTM-450 peek
2002-04-12 by Paul Schreiber
http://www.synthtech.com/pix/m450_3u.jpg The arrangement of the bands is not fixed. But, this *general* layout appeals to me. Note the knobs are *slightly* closer together than the normal modules: 1.5"" center-to-center versus 1.625". Well??!? Paul S.
2002-04-12 by thomas white
I think it looks great. Please explain the Hi Pass and Low pass functions. Are they related to the rows they're in vertically? If not should they be on the leftmost part of the panel so as not to have the bottom pots of this module be between jacks on surrounding modules? Just a thought. I'll but it for sure, maybe 2 depending on the price and end-up features. Finally a 3u panel! Thomas White PS. Any word on the micro VCO stocks, I still await my subscription module? Back in soon? >From: "Paul Schreiber" <synth1@...> >To: "MOTM listserv" <motm@yahoogroups.com> >Subject: [motm] MOTM-450 peek >Date: Fri, 12 Apr 2002 00:46:47 -0500 > >http://www.synthtech.com/pix/m450_3u.jpg > > >The arrangement of the bands is not fixed. But, this *general* layout >appeals to me. Note the >knobs are *slightly* closer together than the normal modules: 1.5"" >center-to-center versus >1.625". > >Well??!? > >Paul S. > > _________________________________________________________________ Send and receive Hotmail on your mobile device: http://mobile.msn.com
2002-04-12 by mate_stubb
Man, whoever that graphic artist is, give him a BIG RAISE! ;>) Moe
2002-04-12 by mmarsh100
This would fit in a 2U, wouldn't it? Either way, too cool... Mike --- In motm@y..., "Paul Schreiber" <synth1@a...> wrote: > http://www.synthtech.com/pix/m450_3u.jpg > > > The arrangement of the bands is not fixed. But, this *general* layout appeals to me. Note the > knobs are *slightly* closer together than the normal modules: 1.5"" center-to-center versus
> 1.625". > > Well??!? > > Paul S.
2002-04-12 by Josue Arias
----- Original Message -----From: thomas whiteSent: Friday, April 12, 2002 6:12 AMSubject: Re: [motm] MOTM-450 peekI think it looks great. Please explain the Hi Pass and Low pass functions.
panel!
Thomas White
Back in soon?
>To: "MOTM listserv"
>1.625".
>Well??!?
>Paul S.
2002-04-12 by George Kisslak
Looks sweet. The 3U layout is great. Does this use active filters, or RLC networks like the Moog? What are the band frequencies? Would a feedback control be possible? Kit price range? George ----- Original Message ----- From: Paul Schreiber <synth1@...> To: MOTM listserv <motm@yahoogroups.com> Sent: Friday, April 12, 2002 1:46 AM Subject: [motm] MOTM-450 peek > http://www.synthtech.com/pix/m450_3u.jpg > > > The arrangement of the bands is not fixed. But, this *general* layout appeals to me. Note the > knobs are *slightly* closer together than the normal modules: 1.5"" center-to-center versus
> 1.625". > > Well??!? > > Paul S. > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
2002-04-12 by Skin Matrix
hello, my only suggestions would be to change the layout of the columns to: hp 8 7 6 5 4 3 2 1 lp led three columns 4 rows. or hp 4 8 3 7 3 6 1 5 lp same as the peek but different knob lay out. also any chance of two inputs so we can do feedback into itself (by way of another module perhaps? Voltage control of the cut off of every filter would be cool too, but this would make the panel far to big, and way too expensive. Maybe there could be an expander module for it? (the expander could have the second input). I am also curious as to whether there is a VC mixer anywhere on the agenda, or if there is one that is of quality anywhere to be had? Mark (Still trying to get the money to start building together) --- Paul Schreiber <synth1@...> wrote: > http://www.synthtech.com/pix/m450_3u.jpg > > > The arrangement of the bands is not fixed. But, this > *general* layout appeals to me. Note the > knobs are *slightly* closer together than the normal > modules: 1.5"" center-to-center versus > 1.625". > > Well??!? > > Paul S. __________________________________________________ Do You Yahoo!? Yahoo! Tax Center - online filing with TurboTax http://taxes.yahoo.com/
HA HA HA! I knew when Paul and I laid this one out that no two people could agree on the layout. You should see some of the other designs I've done already. My personal favorite is the 4U version laid out exactly like the Moog 907. I'll do another couple of versions tonight to run up the flagpole. Then we can have a vote. RE: LP and HP - Ken is correct. There are 8 peaking bands in the middle of the spectrum, tuned for maximum musical effect (I don't know the frequencies, perhaps JH can chime in here). The LP knob controls a different frequency passing everything BELOW the lowest peaking band, and HP passes everything ABOVE the highest peaking band. They are not tuned however to the exact same freq. as the nearest peaking band. Just like a multiband console EQ conceptually, not in terms of operation and filter type, but in terms of how the bands are laid out. Note that this will NOT fit on a 2U panel. There are 10 knobs, 2 jacks, a switch and an LED. Also, I hope people will not freak out about 5 pots in a row, or 1/8" less space between pots. It really is the best layout ergonomically IMO. We shouldn't be slaves to the format, but make it work for us in nonstandard situations. Also, I'd point out that the bottom knobs are not in fact 'getting down in the jacks'. If there is a module below, the only thing there will be more knobs! Moe
2002-04-12 by Tentochi
I am not quite sure why the 1/8" is needed. It looks like there should be enough room; I am sure there is something I am not seeing though. Personally prefer only 4 pots in a row, but I don't have the "perfect" solution either. The original take on this: http://moogarchives.com/m907.htm Moog CE sells these new for US$1295.00. Ouch! --Shemp
> I knew when Paul and I laid this one out that no two people could > agree on the layout. You should see some of the other designs I've > done already. My personal favorite is the 4U version laid out exactly > like the Moog 907. I'll do another couple of versions tonight to run > up the flagpole. Then we can have a vote. > Also, I hope people will not freak out > about 5 pots in a row, or 1/8" less space between pots. It really is > the best layout ergonomically IMO.
This is interesting too: http://moogarchives.com/m914.htm --Shemp
2002-04-12 by Alan Wagner
Hi all,
I was checking out some of the new demos today. The 310 Demos have some really nice FM Bells. Me still being a newbie have come up with all sorts of sounds with my MOTM but have yet to do bells. Would anyone care to jump in and share their favorite FM Bell Patch?
Tx
Al
2002-04-12 by Sikorsky
From: "mate_stubb" <mate_stubb@...> > I knew when Paul and I laid this one out that no two people could > agree on the layout. You should see some of the other designs I've > done already. My personal favorite is the 4U version laid out exactly > like the Moog 907. hmm, 4U..? i like the sound of this :-) > format, but make it work for us in nonstandard situations. Also, I'd > point out that the bottom knobs are not in fact 'getting down in the > jacks'. If there is a module below, the only thing there will be more > knobs! sorry, i meant the adjacent module on the right maybe there's an alco knob one size smaller we could use..? love the idea of an expander module by the way (i can see paul with his head in his hands already) cheers paul b
“I knew when Paul and I laid this one out that no two
people could
agree on the layout.”
Well let’s see there are 218 people on the list so 1 will be happy and 217 will think you should have done differently ;) So go for it, we’ll still buy it, we might complain but we’ll still buy it!!!
BTW, I think the jacks should be placed…………………… !
Al
-----Original
Message-----
[mailto:mate_stubb@...]
Sent: Friday, April 12, 2002 10:06
AM
To: motm@yahoogroups.com
HA HA HA!
bands are laid out.
knobs!
Moe
2002-04-12 by CHRIS PARKER
Just my $0.02.... Keeping future modules within the current MOTM form factor is very important to me. I have purchased several of the available third-party modules (Blacet, Oakley, Stooge, etc.) specifically because MOTM-format panels were available for them. I have not purchased a UEG, mainly because I think the non-MOTM panel is not as aesthetically pleasing when seen against the MOTM system as a whole....I'm sure it's a fine module, but I also don't own any Paia, Doepfer, etc. modules because they just wouldn't "fit right". It seems to me that the current design for the 450 could fit in the 3U panel by moving two of the pots to the same column as the switch/LED without sacrificing the MOTM format...or am I wrong? If this is not possible, I'd vote for a 4U panel that kept the MOTM format. -Chris- >>> "mate_stubb" <mate_stubb@...> 04/12/02 09:05AM >>> HA HA HA! I knew when Paul and I laid this one out that no two people could agree on the layout. You should see some of the other designs I've done already. My personal favorite is the 4U version laid out exactly like the Moog 907. I'll do another couple of versions tonight to run up the flagpole. Then we can have a vote. RE: LP and HP - Ken is correct. There are 8 peaking bands in the middle of the spectrum, tuned for maximum musical effect (I don't know the frequencies, perhaps JH can chime in here). The LP knob controls a different frequency passing everything BELOW the lowest peaking band, and HP passes everything ABOVE the highest peaking band. They are not tuned however to the exact same freq. as the nearest peaking band. Just like a multiband console EQ conceptually, not in terms of operation and filter type, but in terms of how the bands are laid out. Note that this will NOT fit on a 2U panel. There are 10 knobs, 2 jacks, a switch and an LED. Also, I hope people will not freak out about 5 pots in a row, or 1/8" less space between pots. It really is the best layout ergonomically IMO. We shouldn't be slaves to the format, but make it work for us in nonstandard situations. Also, I'd point out that the bottom knobs are not in fact 'getting down in the jacks'. If there is a module below, the only thing there will be more knobs! Moe Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Yes - a 4U w/Moog layout would be awesome! <grin> Looked back and found Paul's "quick update" price estimate of $199-$209 - brain cells slipping...doh! So, I wonder how much more this would be for 4U? George
----- Original Message ----- From: mate_stubb <mate_stubb@...> To: <motm@yahoogroups.com> Sent: Friday, April 12, 2002 10:05 AM Subject: Re: [motm] MOTM-450 peek > HA HA HA! > > I knew when Paul and I laid this one out that no two people could > agree on the layout. You should see some of the other designs I've > done already. My personal favorite is the 4U version laid out exactly > like the Moog 907. I'll do another couple of versions tonight to run > up the flagpole. Then we can have a vote. > <snip>
>>>> Keeping future modules within the current MOTM form factor is very important to me. <snip> It seems to me that the current design for the 450 could fit in the 3U panel by moving two of the pots to the same column as the switch/LED without sacrificing the MOTM format...or am I wrong? <<<< Chris, yes indeed it's possible and I have one design drawn up that way. You'll get a chance to vote on it. Moe
2002-04-12 by jwbarlow@aol.com
1.625".
2002-04-12 by Adam Schabtach
2002-04-12 by media.nai@rcn.com
At 12:46 AM -0500 04/12/02, Paul Schreiber wrote: >http://www.synthtech.com/pix/m450_3u.jpg > > >The arrangement of the bands is not fixed. But, this *general* layout >>appeals to me. Note the knobs are *slightly* closer together than the >>normal modules: 1.5"" center-to-center versus >1.625". > >Well??!? d00D!! Lose the bypass switch and LED, and make it 2U. Other than that it looks great :) If you insist on wasting an entire panel unit (which would be one less 800 for many of us) just for a bypass feature, then at least include a bypass jack. Otherwise, I don't see what could be done with a bypass switch that couldn't be done with patch cords and a typical monitoring setup. If the 450 is 2U, anyone who buys two of them would save enough room for a full-fledged MOTM-700. You sell more modules. They get a much better system. Everyone's happy :)
2002-04-12 by Jeffrey Pontius
> Just my $0.02.... > My counter $0.02: Audio and cv quality and options are *the* primary objectives over any other consideration; with panel ergonomics second (enhances our interfacing with the synthesizer - essential for concentration on 'noise' making), and 'looks' trailing a distant third. Of course, cost constrains all of these (from our viewpoints and from Paul's viewpoint - it is just reality). IMHO a synthesizer is to make noise, not be a 'sculpture' piece (and one doesn't 'hear' the looks). I would gladly trade a 'nice' look for more audio/cv function. This is one reason why I do have a UEG - it's useful, functional aspects clearly outweigh it's semi-motm look. Ergonomics not only involve spacings of knobs, jacks, readablity of pot scales, ..., but also include spacings between modules on a 2-dimensional surface (with some small angling in some systems). I would guess (but maybe this is my own inability) that modules that are close are connected more often than modules that are distant. So given the behind the panel layout constraints, I would think that a reasonably ergonomic panel that is 3U would be preferable to a 4U panel that 'looks nicer.' So for the 450, a slightly narrower motm spacing of knobs to obtain a 3U vs. a 4U is a good decision. [Personal bias: There are some (maybe few) of us that do have physical space constraints, which is why I think the micro-modules are a motm plus]. Anyway, this is not targeted at Chris P. or anyone else; we all have our preferences. Mine just happens to be the noise making and I hope we keep that up front. Going for lunch, Jeff
2002-04-12 by Scott Evans, Gen Mgr
media.nai@... wrote: > > Lose the bypass switch and LED, and make it 2U. > > I don't see what could be done with a bypass switch that > couldn't be done with patch cords and a typical monitoring setup. > I am in agreement here. If the intent is just to see how the sound is modified by the bypass switch, this can easily be done with some creative patching. Also, what about having the panel graphic include the center frequency for the filter, as they are not sweepable or parametric. Just a thought. Scott
Bell/metallic patches are really fun to do on the MOTM. There are many ways to get something interesting but here is a suggestion for a starting point: * Fire up a 300, use the SINE out. Put another audio SINE into FM1, EXP mode. I use the 420 with RES cranked up all the way for this but you could use any other oscillator. * Run the output of the 300 to a 440 (or other filter). Chop off highs to taste. I use an 800 to shape the filter response: very fast attack, slower decay. * Run the output of the filter into a VCA, again shaped by an 800 with fast attack and slow decay. Now you can: * Play with the frequency of the modulating oscillator for fun and profit. Add an envelope to shape the response. * Play with the filter settings. * Play with the 800 settings. * Modulate another 300 with the output of the 1st 300 (!) * etc. Mike --- In motm@y..., "Alan Wagner" <Aardvark-mi@a...> wrote: > Hi all, > > I was checking out some of the new demos today. The 310 Demos have some > really nice FM Bells. Me still being a newbie have come up with all sorts of > sounds with my MOTM but have yet to do bells. Would anyone care to jump in
> and share their favorite FM Bell Patch? > > Tx > Al
>>>> d00D!! Lose the bypass switch and LED, and make it 2U. Other than that it looks great :) <<<< dOOD! Once again: 10 pots and 2 jacks WILL NOT FIT into 2U! Moe
I assumed the LED was clip indicator, but I gather from other posts that it is really an ON indicator. We have the space, how about a clip LED as well? Mike --- In motm@y..., "Paul Schreiber" <synth1@a...> wrote: > http://www.synthtech.com/pix/m450_3u.jpg > > > The arrangement of the bands is not fixed. But, this *general* layout appeals to me. Note the > knobs are *slightly* closer together than the normal modules: 1.5"" center-to-center versus
>>>> Also, what about having the panel graphic include the center frequency for the filter, as they are not sweepable or parametric. Just a thought. <<<< I'm down with that. If I could find out the center frequencies, I'd mock it up. Moe
2002-04-12 by Vehorn, Benjamin
2002-04-13 by Charles Stella
The layout looks great! I am pysched to have an MOTM quality EQ. As far
as the controls I am not sure if the board layout determined the
positioning or not. If the low shelf control is the 'lowest' band then
the bands should count up then descend with the high shelf control being
at the bottom right of the low shelf control.
Also, the 'bypass on' seems counter intuitive to me. I know the 820
works like this so there is some precedent for standardization, but I
would rather see 'EQ IN' or 'Engage' with the LED lit when the unit is
on like most equipment in ones studio. Charles.
mate_stubb wrote:
> HA HA HA!
> bands are laid out.
> knobs!
> Moe
> Yahoo! Groups Sponsor
ADVERTISEMENT
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.2002-04-13 by Graham Hunter
I haven't read all the e-mails following this yet, but I've just got to comment now... > From: "CHRIS PARKER" <cparker@...> > Subject: Re: MOTM-450 peek > > Keeping future modules within the current MOTM form factor is very important > to me. > > I have not purchased a UEG, mainly because I think the non-MOTM > panel is not as aesthetically pleasing when seen against the MOTM system as a > whole.... I have a UEG, and it looks just fine in the rack next to the MOTM gear. It's a very very cool module, and worth every penny. If this is all that's stopping you from buying one, then you really need to give it another shot. Why don't you download the user's manual from the Encore site to see what it can do before making your final decision to leave this one out of your rack. Graham __________________________________________________ Do You Yahoo!? Yahoo! Tax Center - online filing with TurboTax http://taxes.yahoo.com/
2002-04-15 by media.nai@rcn.com
At 6:03 PM +0000 04/12/02, mate_stubb wrote: > >>Lose the bypass switch and LED, and make it 2U. > >dOOD! Once again: 10 pots and 2 jacks WILL NOT FIT into 2U! Are you 100% sure?? Even with a shoehorn and a bucket of grease, you can't get them in there?? Wasting an entire panel unit just to add a useless bypass feature would be a real shame. I'd go back and try again. Maybe you have to slant the knobs a bit. If it's going to be 3U, the knobs might as well go in their regular places. As far as the electrical design is concerned, if you are keeping the bypass switch, a 9th knob for MAKE-UP GAIN should then be added as well. Otherwise, there is no point in having a bypass switch because making comparisons without matching the levels is impossible!! Look at any EQ with a bypass switch. If it's going to have a bypass feature, it needs a pot for make-up gain. Having one without the other looks retarded. I realize that motm is not intended as meat and potatoes gear. Yet, equalizers with a unique sound often become desirable, even legendary, pieces of recording equipment. I've never seen a Moog used that way, but that doesn't mean it's never been done. Perhaps the Moog was too noisy. Thirty years ago, most solid state did not sound good. Considering what it takes to rackmount many popular board modules, mounting two synth modules sideways and finding a +/-15 supply is nothing. A more synthy feature would be a wet/dry knob. An inverted output jack, or an inverting switch before the wet/dry mix, could be added as well. With 3U there would be room. If it's going to be 3U it should have 3U worth of stuff.
2002-04-17 by jhaible
> If it has a bypass switch then it needs a gain control.
> If it doesn't have a bypass switch then it doesn't need a gain control.
> It's ridiculous to have one without the other. No one does that.
No one ?
Hmm, I did exactly that, it works great, and as my prototype is the only
unit in existence, I could even conclude that it works to 100% ! (;->)
Ok, this was spoken tongue-in-cheek, please don't take it seriously.
(And I always run my final mix thru a compressor.)
Now, more seriously: I see all your points, and I see reasons for all
three versions:
Switch and Gain control - most comfort, most panel space, most expensive.
None of these - cheaper, less panel space
Switch only - good if you want to remove it quickly from the signal chain,
without taking care of level matching. (For instance,
because
you have a lot of other gain pots in the signal
chain.)
And there are two more options:
Gain control and no switch - that's one I cannot find any use for (but
someone
else surely will)
Gain control which adjusts itself with a motor pot, according to some
criteria
like peak level or RMS level - now *that* would be the ultimate
solution, wouldn't it ? (;>)
JH.2002-04-17 by mmarsh100
Just to clarify - you're not quoting me here, although I agree that the ideal would be a gain pot and a bypass switch (or neither!). Mike --- In motm@y..., "jhaible" <jhaible@d...> wrote: > > If it has a bypass switch then it needs a gain control. > > > > If it doesn't have a bypass switch then it doesn't need a gain control. > > > > It's ridiculous to have one without the other. No one does that. > > No one ? > Hmm, I did exactly that, it works great, and as my prototype is the only > unit in existence, I could even conclude that it works to 100% ! (;- >) > > Ok, this was spoken tongue-in-cheek, please don't take it seriously. > (And I always run my final mix thru a compressor.) > > Now, more seriously: I see all your points, and I see reasons for all > three versions: > Switch and Gain control - most comfort, most panel space, most expensive. > None of these - cheaper, less panel space > Switch only - good if you want to remove it quickly from the signal chain, > without taking care of level matching. (For instance, > because > you have a lot of other gain pots in the signal > chain.) > > And there are two more options: > Gain control and no switch - that's one I cannot find any use for (but > someone > else surely will) > Gain control which adjusts itself with a motor pot, according to some > criteria > like peak level or RMS level - now *that* would be the ultimate
> solution, wouldn't it ? (;>) > > JH.
2002-04-18 by media.nai@rcn.com
At 9:42 PM +0200 04/17/02, jhaible wrote: > >Now, more seriously: I see all your points, and I see reasons for all >three versions: Oh, that's good. There was snow last week, and it was 96ºF yesterday, so it's hard to tell if I'm making any sense ;) >Switch and Gain control - most comfort, most panel space, most expensive. >None of these - cheaper, less panel space >Switch only - good if you want to remove it quickly from the signal chain, >without taking care of level matching. (For instance, because >you have a lot of other gain pots in the signal chain.) According to Moe, it will take 3U even if the bypass feature is omitted entirely. So I'm thinking, if it's going to take up 3U, it might as well have 3U worth of stuff. How much would adding a gain pot increase the cost?? And now for the really good question: Why does a bypass switch, that doesn't have a pedal input or any kind of external control, need an LED?? Is that for people with some kind of weird eye disease who can only see LED's but can't read switches?? :) >Gain control which adjusts itself with a motor pot, according to some >criteria like peak level or RMS level - now *that* would be the ultimate >solution, wouldn't it ? (;>) Oh, I'm sure that will fit behind the Mark Technology MARK-450 ;)
