Re: [motm] MIDI Boxes? Naw. CV Controllers!
2002-03-25 by mate_stubb
A performance controller is on my list of stuff to do. There's even a place on the Hot Rod site for a later page. Mine will be a slim wedge to sit on top of a CV keyboard, with momentary and latched gate switches, joysticks with attenuators, cv outputs with attenuators, and something exotic like a ribbon or maybe capacitance touch plates. Use a multiconnector cable to carry power and outputs to a panel, and you're there! Moe http://www.hotrodmotm.com > ----- Original Message ----- > From: Brousseau, Paul E (Paul) <noise@A...> > Larry, I don't follow your stooginess about the -15V > power and its ramifications. Help? Summing op amps invert. So, unless you want to follow it with another amp to get it back positve. Of course, all that goes to heck because the incoming CV gets inverted too. So, it was a good thought, but may not be worth a darn int he final conception. Cable between the box and panel gets a whole lot more simple if the incoming CV attenuators are on the panel as I see it. :) But, then I am only a Stooge and must insert standard disclaimer.
