waveforms
waveforms
2002-03-20 by mmarsh100
Hello all -
I just had an interesting session with my audio redcording software
(in this case Cool Edit 2000).  I hooked a 300 directly to my console
and recorded a bit of each waveform.  Did the same for the 310.
This is probably a great opportunity to show how knowledgeable I
truly am.
Let's start with the SQUARE out: it's not square! It goes straight
up, then exponentially down, creating a sort-of fast-attack
exponential-decay wave form above zero, then inverts the same
waveform below zero.  Could this be why the square output has always
seemd a little buzzy to me?  Not a bad thing, mind you.
The SAW looks just like the positive half of the SQUARE, except that
it dips below zero a couple of db.
The 310 OUT is the same as 300 SQUARE when 310 SHAPE is a 10.  SHAPE
at 0 gives same as 300 SAW and shape at 5 is a combo of the two.
SO the stupid question: why isn't the SQUARE square and the SAW saw?
Mike
Re: [motm] waveforms
2002-03-20 by Scott Juskiw
Your console is probably AC coupled so it's acting like a filter and
changing the shape of the waveforms as well as removing any perceived
DC bias. I test all my modules with a DC coupled scope and they look
exactly as advertised.
2002-03-20 by KA4HJH
Your sound card's sampling rate is way too low. Try bumping it up to 1 MHz
or so and the waveform will look very square.  ;-)
Seriously, that's what a square wave looks like without all the high
frequency harmonics. Kinda scary but normal.
Terry Bowman, KA4HJH
"The Mac Doctor"
"By the end of Chuck Statler's 'Rock Videos' of Devo we agreed that even if
Devo did not take the stage it was still the best concert any of us had
ever attended." --Kim Thayil (Soundgardern), 1995
2002-03-20 by djarum11
mike, you say it sounds buzzy. there may be a pcb error (happened to me).
just to be sure, check it with a scope on the DC setting.
mark
At 10:24 PM 3/20/02 +0000, you wrote:
>Hello all -
>truly am.
>Mike
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Re: waveforms
2002-03-21 by mmarsh100
Thanks, Terry.  Glad to know I'm normal :) I've hadseveral replies to
this post both on and off list.  I will summarize these tonight and
post them.  I might also post screenshots of the waveforms.  I'm
still alittle confused...
Mike
always
to 1 MHz
> "The Mac Doctor"
even if
had
Re: [motm] Re: waveforms
2002-03-21 by Paul Schreiber
You are observing a "hidden" HPF (high pass filter), caused by the reactance of the AC coupling
network on the sound card.
Try increasing the VCO frequency to like '7' tick mark.
In order not to see 'tilt' of a square wave, the 3dB point of an AC couping stage has be be about
7 *times* lower than the frequency of interest.
The sound card probably has it's lower 3dB point set for voice, about 200Hz. This is why MOTM
demos recorded on SoundBlasters sound terrible.
If you aren't convinced, I'll fire up my 2Gs/sec digital scope with the 500Mhz probes :)
Re: waveforms
Mystery solved.  I admit to lying before: the output of the 300 was
going into the 410 with MIX completely dry and MIX OUT to the
console.  What's wrong with this picture, anyone?
Feeling a bit dorky at the moment,
Mike
2002-03-21 by KA4HJH
The first time I saw the *output* from a sound card being used as a square
wave generator on a 'scope I thought "where are all the harmonics?--is
something acting like a resonating filter?" I switched to DC and it looked
the same, and then it hit me--low sampling rate.
This is the image that popped into my mind when I first read your post, but
as it happens it sounds like that's not what was happening in this case,
and Paul and Scott are probably dead on.
"The Mac Doctor"
"It gets calls when nothing else works"--Walter Eugene Scott, PdD,
explaining somewhat facetiously why a "TV preacher" was smoking a cigar.
2002-03-21 by Sikorsky
hello all,
i did almost exactly the same thing last night - i was putting a freeware
tuner through it's paces (chromatia from www.fmjsoft.com) and wandered why
the tuner was going bananas...
...answer - i was using the output of the 420 VCF instead direct from the
VCO
cheers paul b
sheffield
uk
Re: waveforms
Well, AS THE MANUAL PLAINLY STATES (Paul told me to RTFM and I always
follow his instructions to the letter) the input of the 410 is
buffered by U2B then goes to U2A: "U2A forms a 65 Hz high-pass
filter".
Now folks will see why I'm feeleing dorky,
Mike
> Mike
