101 assembly question
2002-01-19 by gooboworks
Since Paul is busy with NAMM, I will post this question here. Assembling the 101 Noise S&H, on page 10 a coax cable is soldered into the CLOCK pads at J5. The instructions do not say to lay the cable flat and secure with a tie wrap, however there are tie wrap holes on the PCB and spare tie wraps came with the kit. Do I lay this coax wire flat on the PCB and tie wrap it down to the board, or does the wire come straight up from the connection? Thanks Andy Miller
