Miniwave instructions revised & Time Machine progress
2002-01-18 by J. Larry Hendry
The Blacet Miniwave to MOTM conversion instructions have been revised to "Revision 1" dated 01/17/2002. Mostly, I corrected some stupid typos I missed originally. However, one significant error was found as I called out R20 as a 20K resistor and it is really a 1K resistor. Thanks to Scott Juskiw for catching this mistake. I ordered my second Miniwave module when I ordered by extra EPROM from John. If you don't have a Miniwave, I highly recommend you get one. Awesome ! I have completed my Time Machine and it works beautifully. I am about 75% done with the instructions. I have one or two other "modification" issues I have mailed John about. I may add one more diode and change another resistor or two. Like the Miniwave, there will be a very detailed set of instructions with photos. However, I plan to include all the modifications in these instructions to keep everything in one place. Changes are more significant than the Miniwave. I will mark the modification in the instructions in case you elect not to make the changes. But, you will want to I think. :) Next on the list is getting caught up on drilling end caps and back to that SKB pop-up case back cover. I need to get that finished. I wish I was at NAMM. :) Stooge Larry
