OMS-820
2001-11-22 by Tony Allgood
Hi all, The OMS-820 PCBs have now arrived and are now starting to ship. For more information go to: http://www.oakleysound.com/oms-820.htm Thanks to all who have ordered already. Cheers, Tony
2001-11-27 by psygfx@yahoo.com
Larry sparked my interest on a multiples panel. I like probably many others of you have skb pop up cases with a little extra space. Why not get a piece of metal with a bunch of jacks (kinda like a pathcbay but multiples) and make a 19in 1 spc multiple panel. Has this already been discussed? Any idea where to get a piece of metal to use? matt _________________________________________________________ Do You Yahoo!? Get your free @... address at http://mail.yahoo.com
2001-11-27 by sikorsky
> Larry sparked my interest on a multiples panel. I like probably many > others of you have skb pop up cases with a little extra space. Why not > get a piece of metal with a bunch of jacks (kinda like a pathcbay but > multiples) and make a 19in 1 spc multiple panel. Has this already been > discussed? Any idea where to get a piece of metal to use? > matt hello all, that's just what i've been up to on my 2U panel flat mounted a 960 power distribution board (i have an external power supply for my skb cases), and in the dead space behind that mounted a joystick from an old video game - thanks to larry for the buffer circuit, also i've put two 4 way mults, a pair of three source selection switches for live use, and a four way tie line to the outside world i couldn't say where to get a panel in the US, mouser, digikey i suppose will have then - make sure you get one with a lip, not just a flat 2U panel cheers paul b
2001-11-27 by doc@trocarrecords.com
h3y, i use a behringer patchbay. i have the nodules patched together through the back so you get 12 sets of 1 in/3 out. you can also patch more together to get more outs off one input. have a good one... peace, doc --- In motm@y..., <psygfx@y...> wrote: > Larry sparked my interest on a multiples panel. I like probably many > others of you have skb pop up cases with a little extra space. Why not > get a piece of metal with a bunch of jacks (kinda like a pathcbay but > multiples) and make a 19in 1 spc multiple panel. Has this already been
> discussed? Any idea where to get a piece of metal to use? > matt > > > _________________________________________________________ > Do You Yahoo!? > Get your free @... address at http://mail.yaho
2001-11-27 by George Kisslak
Hey doc, I'm curious, did you use patch cables in the back or did you hardwire 'em together? (I have a similar [Furman] patchbay, not sure which method to use.) George ----- Original Message -----
From: <doc@...> To: <motm@yahoogroups.com> Sent: Tuesday, November 27, 2001 12:03 PM Subject: [motm] Re: 19in Multiples Rack Panel > h3y, > i use a behringer patchbay. i have the nodules patched together > through the back so you get 12 sets of 1 in/3 out. you can also > patch > more together to get more outs off one input. > have a good one... > peace, > doc > > > --- In motm@y..., <psygfx@y...> wrote: > > Larry sparked my interest on a multiples panel. I like probably many > > others of you have skb pop up cases with a little extra space. Why > not > > get a piece of metal with a bunch of jacks (kinda like a pathcbay > but > > multiples) and make a 19in 1 spc multiple panel. Has this already > been > > discussed? Any idea where to get a piece of metal to use? > > matt
2001-11-27 by Scott Gibbons
> I can't really vouch for the quality of the jacks, but they should be > decent, if not superb. I've got one and the quality of the jacks really is top notch. Where Behringer cut costs is, they're not balanced.
2001-11-28 by psygfx@yahoo.com
Anyone know if this would work for 1/4" connectors? Its says "xlr and neutrik" http://www.middleatlantic.com/rackac/chassis/chassis.htm _________________________________________________________ Do You Yahoo!? Get your free @... address at http://mail.yahoo.com
2001-11-28 by sucrosemusic@yahoo.com
Not really. neutrik connectors and XLR connecters use much larger mounting holes. you'd probably be better off getting one designed for 1/4" jacks. Try out the behringer patchbay, seriously, they're stupidly cheap. www.behringer.com or check out accessories at www.raxxess.com --- In motm@y..., <psygfx@y...> wrote: > Anyone know if this would work for 1/4" connectors? Its says "xlr and
> neutrik" > > http://www.middleatlantic.com/rackac/chassis/chassis.htm > > > > _________________________________________________________ > Do You Yahoo!? > Get your free @... address at http://mail.yahoo.com
How would I convert a patchbay to a multiples panel? I guess that's easier and cheaper than drilling holes and buying jacks. Thanks matt
-----Original Message----- From: sucrosemusic@... [mailto:sucrosemusic@...] Sent: Tuesday, November 27, 2001 4:58 PM To: motm@yahoogroups.com Subject: [motm] Re: 19in Multiples Rack Panel Not really. neutrik connectors and XLR connecters use much larger mounting holes. you'd probably be better off getting one designed for 1/4" jacks. Try out the behringer patchbay, seriously, they're stupidly cheap. www.behringer.com or check out accessories at www.raxxess.com --- In motm@y..., <psygfx@y...> wrote: > Anyone know if this would work for 1/4" connectors? Its says "xlr and > neutrik" > > http://www.middleatlantic.com/rackac/chassis/chassis.htm > > > > _________________________________________________________ > Do You Yahoo!? > Get your free @... address at http://mail.yahoo.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ _________________________________________________________ Do You Yahoo!? Get your free @... address at http://mail.yahoo.com
2001-11-28 by Dave Hylander
The Behringer is the way to go. 8th Street Music has them for $39! www.8thstreet.com I use a similar on my MOTM cab for both multiples, and patch points to a 8 channel mixer and the Kenton Pro-4. Both have their jacks on the back of the units. Works great. dave At 12:57 AM 11/28/2001 +0000, sucrosemusic@... wrote:
>Not really. neutrik connectors and XLR connecters use much larger >mounting holes. you'd probably be better off getting one designed >for 1/4" jacks. Try out the behringer patchbay, seriously, they're >stupidly cheap. www.behringer.com or check out accessories at >www.raxxess.com
Well, depending on how you have the normalling set up on the behringer one... I'd use "Paralell." The thing's set up in 2 rows of 24 jacks, 2 rows on the front, 2 on the back, for 96 jacks total.. "Paralell" takes each column, front and back, and connects them. So, your module could plug into the back of the unit, say the top jack, and you could run a short patch cable from the bottom jack in the back to the next column over. This would give 4 jacks on the front that came from the one module's output/input/whatever. I can't really vouch for the quality of the jacks, but they should be decent, if not superb. http://www.behringer.com/eng/products/audiosolutions/px2000.htm is a link that gives some info on the behringer patchbay. Most of this stuff should apply to all patchbays. You should read the manual that's posted there to get a better idea how the routing on the thing works. --- In motm@y..., <psygfx@y...> wrote:
> How would I convert a patchbay to a multiples panel? I guess that's > easier and cheaper than drilling holes and buying jacks. > Thanks > matt > > -----Original Message----- > From: sucrosemusic@y... [mailto:sucrosemusic@y...] > Sent: Tuesday, November 27, 2001 4:58 PM > To: motm@y... > Subject: [motm] Re: 19in Multiples Rack Panel > > Not really. neutrik connectors and XLR connecters use much larger > mounting holes. you'd probably be better off getting one designed > for 1/4" jacks. Try out the behringer patchbay, seriously, they're > stupidly cheap. www.behringer.com or check out accessories at > www.raxxess.com > > --- In motm@y..., <psygfx@y...> wrote: > > Anyone know if this would work for 1/4" connectors? Its says "xlr > and > > neutrik" > > > > http://www.middleatlantic.com/rackac/chassis/chassis.htm > > > > > > > > _________________________________________________________ > > Do You Yahoo!? > > Get your free @... address at http://mail.yahoo.com > > > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > > > > _________________________________________________________ > Do You Yahoo!? > Get your free @... address at http://mail.yahoo.com
The patch bay I have, you set it for half normal, and then run a jumper patch cord on the back between the two jacks. That gives you four connected jacks on the front of the patch bay. Here's a pic of what it looks like on the back. http://www.hylander.com/images/motm/Motmback.jpg dave At 05:07 PM 11/27/2001 -0800, psygfx@... wrote:
>How would I convert a patchbay to a multiples panel? I guess that's >easier and cheaper than drilling holes and buying jacks. >Thanks
2001-11-28 by Thomas Hudson
On Tuesday, November 27, 2001, at 05:37 PM, Dave Hylander wrote: > http://www.hylander.com/images/motm/Motmback.jpg Poking around (can't resist) I noticed you had a jpeg of a MIDIMan SurfaceOne (http://www.hylander.com/images/motm/surfaceone.jpg) I've been considering one. What do you think of it? Thomas
Nice! very inventive. And here I was going to build one.
-----Original Message----- From: Dave Hylander [mailto:david@...] Sent: Tuesday, November 27, 2001 5:37 PM To: psygfx@...; sucrosemusic@...; motm@yahoogroups.com Subject: RE: [motm] Re: 19in Multiples Rack Panel The patch bay I have, you set it for half normal, and then run a jumper patch cord on the back between the two jacks. That gives you four connected jacks on the front of the patch bay. Here's a pic of what it looks like on the back. http://www.hylander.com/images/motm/Motmback.jpg dave At 05:07 PM 11/27/2001 -0800, psygfx@... wrote: >How would I convert a patchbay to a multiples panel? I guess that's >easier and cheaper than drilling holes and buying jacks. >Thanks _________________________________________________________ Do You Yahoo!? Get your free @... address at http://mail.yahoo.com
I don't have one of these, but am considering it as well. I don't think it's actually out yet. Jim W. sent me this pic awhile back. I think I remember him saying this is the prototype. Looks cool though...... dave At 05:51 PM 11/27/2001 -0800, Thomas Hudson wrote:
>Poking around (can't resist) I noticed you had a jpeg of >a MIDIMan SurfaceOne (http://www.hylander.com/images/motm/surfaceone.jpg) > >I've been considering one. What do you think of it?
Holy mackerel. Everyone should check out that images directory. My only question... why monitor 1s? And that brings up a question... what monitors do you think I should get? I know real analog can produce sounds way past what my crummy bookshelf speakers make, so what monitors are good 'n safe? -Geoff (and yes, I will be spending money, Paul, no worries there =] ) --- In motm@y..., Dave Hylander <david@h...> wrote: > The patch bay I have, you set it for half normal, and then run a jumper > patch cord on the back between the two jacks. That gives you four > connected jacks on the front of the patch bay. Here's a pic of what it > looks like on the back. http://www.hylander.com/images/motm/Motmback.jpg
> > dave > > > At 05:07 PM 11/27/2001 -0800, psygfx@y... wrote: > >How would I convert a patchbay to a multiples panel? I guess that's > >easier and cheaper than drilling holes and buying jacks. > >Thanks
Well, back when I bought them years ago, they were pretty good for the price I paid. Now I keep buying mo' motm and such, as well as feeding my guitar habit. Did you check this one out? http://www.hylander.com/images/guitar/Driskillfullbody.JPG It a hand made custom by Joe Driskill. Aside from coil tap humbuckers and single coil pickups, it has a custom bridge with 6 piezo's in it to output midi pitch. It's a real fun way to motm. dave At 02:04 AM 11/28/2001 +0000, sucrosemusic@... wrote:
>Holy mackerel. Everyone should check out that images directory. My >only question... why monitor 1s? > >And that brings up a question... what monitors do you think I should >get? I know real analog can produce sounds way past what my crummy >bookshelf speakers make, so what monitors are good 'n safe?
2001-11-28 by mark@indole.net
>How would I convert a patchbay to a multiples panel? I guess that's >easier and cheaper than drilling holes and buying jacks. Yes, that would be easier than building one from scratch, but the easiest and most flexible solution would be the MOTM-910 which comes already assembled and labeled. Check it out. Anyway, MOTM uses shielded connections and most 1/4" patchbays use switched jacks. If these connections remain, the redundant connections might create ground loops. Ignoring the possiblity of ground loops, most 1/4" patchbays (such as those made by Re'an and the folks who re-label them) have jacks on both the front and the back. You don't need that. After adding in the cost of plugs and cables to use on the back jacks, it might be more expensive than simply buying a blank 19" rack panel and 24 jacks. If you want to save yourself work and are willing spend money on something that is "MOTM quality", ADC offers several different patchbay panel kits (they come with jacks installed, but they are unconnected) that you could easily stitch with bus wire to create quality mults. In selecting an assembled bay, you might want to keep in mind that Behringer is the Doepfer of audio equipment, and there is nothing more annoying than a jack that doesn't work when you need it.
