OT: dead Korg Sd400 analog delay
2001-10-19 by Jeffrey Pontius
I apologize if this is OT for the motm list (let me know Paul), but I thought I would try my trusty motm colleages first since I know that there is a lot of good expertise here. Victim: Korg sd400 analog delay Symptoms: Does not power up: Worked fine one evening, the next, nothing. Evaluation so far: After opening up the unit, the fuse looks ok (but the ends of the fuse appear to be encased in not very clear plastic and the fuse ends might be soldered directly to the wires from the pushbutton switch - I can't see the connections clearly without opening up the plastic). 'On' power light does not light. Transformer does not become warm after having the pushbutton in 'on' position for 15 min. Could it be the switch (but this did not show any intermittent problems previously - mechanically it visually appears to work)? Being a novice at this stuff, this is as far as I can confidenctly go without further assistance. I have a DVM. Any suggestions appreciated. Thanks, Jeff
