[OT] Korg Delta/Kenton Pro-2000
2001-10-14 by mrnezumi@yahoo.com
Sorry for this slightly off-topic question. I have a Korg Delta; a low budget synth/organ/string keyboard (top-divided VCO, I belive)from 1981. It has inputs for "vcf fcm" and "trigger". Can I control this thing with my Kenton Pro-2000? Hz/volt? Can I damage anything if I just give it a go? Thanx, Mr. Nezumi
2001-10-14 by J. Larry Hendry
My guess is no. My understanding is limited. I will throw out what I know and think I know for those more informed to build on or correct. The "vcf fcm" sounds like it might be for foot pedal to control the filter frequency cut-off. Is the trigger is more likely an output? Or, is it labeled input? If I remember this board correctly, it is more of what I would call an ensemble than a synth. Since you have all tones available at once, there is no such thing as voltage control of any oscillator (remember that are all derived from top-down division). So, it is more organ like. The tones are simply keyed into the mix, but are active all the time. The advantage of these machines is unlimited poly. However, you usually do not have much control over waveshape (maybe some tabs). They can make some boss analog string sounds with appropriate external processing. How about running the output through your MOTM-410? Larry H
----- Original Message ----- From: <mrnezumi@...> To: <motm@yahoogroups.com> Sent: Sunday, October 14, 2001 11:20 AM Subject: [motm] [OT] Korg Delta/Kenton Pro-2000 Sorry for this slightly off-topic question. I have a Korg Delta; a low budget synth/organ/string keyboard (top-divided VCO, I belive)from 1981. It has inputs for "vcf fcm" and "trigger". Can I control this thing with my Kenton Pro-2000? Hz/volt? Can I damage anything if I just give it a go? Thanx, Mr. Nezumi Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2001-10-14 by Mr. Nezumi
Thanks for the comments Larry. I have owned the Delta for several years, but I am far from the original owner. I have never been able to locate an owner's manual and there is conflicting/confusing info on the web. I agree that the "VCF fcm in" is most likely for a foot pedal (but I'm ignorant as to what the difference is between a CV from the Kenton and a CV from a pedal - though with the introduction of the 850 I'm gathering there is one). The trigger is most definetly an input, as it has a trigger output jack as well. Whereas it does have "full" polyphony, I had hoped the maybe it could be controlled monophonically with the trigger in. I'm at loss for what else it could trigger. I put 'full' in quotations because even though it has polyphony it has only one envelope for all voices. This can be used to great effect, but it is a one-trick-pony. The Delta does a passable (but far from great) string sound, but it really excels at robot era Kraftwerk sounds. There are trim pots to tweak the Q and cut-off and it can be made to squeal in an acidic manner. If I pipe in a CV from the Kenton through the trigger-in could it hurt anything? Hz/v? Thanx, Mr. Nezumi (meow) --- "J. Larry Hendry" <jlarryh@...> wrote: > My guess is no. My understanding is limited. I > will throw out what I know > and think I know for those more informed to build > on or correct. The "vcf > fcm" sounds like it might be for foot pedal to > control the filter frequency > cut-off. Is the trigger is more likely an > output? Or, is it labeled input? > > If I remember this board correctly, it is more of > what I would call an > ensemble than a synth. Since you have all tones > available at once, there is > no such thing as voltage control of any > oscillator (remember that are all > derived from top-down division). So, it is more > organ like. The tones are > simply keyed into the mix, but are active all the > time. > > The advantage of these machines is unlimited > poly. However, you usually do > not have much control over waveshape (maybe some > tabs). They can make some > boss analog string sounds with appropriate > external processing. How about > running the output through your MOTM-410? > > Larry H > - > From: <mrnezumi@...> > > Sorry for this slightly off-topic question. I > have a Korg Delta; a low > budget synth/organ/string keyboard (top-divided > VCO, I belive)from > 1981. It has inputs for "vcf fcm" and "trigger". > Can I control this > thing with my Kenton Pro-2000? Hz/volt? Can I > damage anything if I > just give it a go? > > Thanx, > Mr. Nezumi > > __________________________________________________ Do You Yahoo!? Make a great connection at Yahoo! Personals. http://personals.yahoo.com
