Re: motm vs oakley noise modules
2001-09-18 by sikorsky
From: Jeffrey Pontius <jpont@...> To: sikorsky <vulture.squadron@...> Sent: Tuesday, September 18, 2001 1:59 AM > If I remember correctly, in one post you mentioned that you had both > motm and oakley noise modules. If you would like, and at your > convenience, I (and I bet others) would appreciate hearing your opinions > contrasting these 2 modules. I have the motm module, but I'm interested > if there are difference in the oakley noise module that would make it > worth incorporating into my system. > Thanks, Jeff hello all, so here it is - the oakley module has three noise outputs, white pink and 'infra-red', along with manual high pass & low pass filters i've put mine on a 2U panel, but with normalisation, you could easily fit it in 1U. as far as i'm concerned noise is noise, but the 'infra-red' output is more like 'wandering DC' it's slow enough for my favourite app which is put some downward only lag over the noise, patch it to the cv input of a vca to control found voices during a mix / session - it's great, i have a jack kerouac cd, nice long reverb, and i just comes in and tails off at random. the motm slow / random output is a little too fast/random for this, though i'm sure that simple filtering or lag processing would work - though i've never gotten it quite right. off course on the oakley module you have a pair of manual filters, on the motm module you have sample & hold - they both have noise outputs, but they are different modules and i think they compliment each other in a system. i have an motm 100, 101, and an oakley noise/filter (i think it ended up being an OMS-340) cheers paul b
