Metric considerations - Was: dress end caps for your MOTM ??
2001-09-09 by J. Larry Hendry
Thanks for this heads up Gert. I take it from what you have written that a M6 diameter is greater than the 10/32 used as the US rack standard screw. I will be sure to pick up some M6 and make sure this issue is addressed. I have actually planned to oversize these holes anyway to provide some slop to allow fitting similar to the 15/1000 slop and oversized mounting holes provided by Paul on the modules. Larry
----- Original Message ----- From: Gert Jalass <gjalass@...> IMPORTANT for the people in Europe (like me) : The holes (outlets) for the mounting screws should be (at least) of 6 mm width (which is obviously more than the rails Paul did supply have ). This would allow to use them without modifying the racks. They have metric nuts - M6.
