MOTM-310 time again
MOTM-310 time again
2001-08-31 by Paul Schreiber
Now that Larry is hard at work (cough cough) on the pedal interface, I'm
focusing on the MOTM-310 MicroVCO.
To refresh: this is a lower cost VCO that shares MOTM-800 EG panel, bracket,
and pcb size. That means 4 knobs
and 4 jacks.
In order to match MOTM-300 performance, and to use common parts I want to
keep it SAW-based (as opposed
to TRI-based). Looking at the pcb space and cost target ($169-179 kit) I
propose the following:
4 knobs are:
COARSE
FINE
FM (attenuator)
WIDTH (of pulse)
4 jacks are:
1V/OCT
FM
SAW
PULSE
This minimizes parts count. Having a 'blend' pot (say between SQUARE and
TRI) looks like too many parts to
fit on the board. Plus it adds $10-$15 to the cost. Since this main function
of the '310 is to 'beef up' the mix with
existing '300s, and to use as a sync generator to other '300s, this looks
like the best fit.
The only other possibility is: the 4th pots is a 'blend'. The VCO has 1 OUT.
The 4th jack is PWM IN. With no
plug inserted, the PULSE is 50%. Else, the input is a -5V to +5V pulse width
control (no input attenuation).
So you can get SAW to PULSE with the blend. This is not as gnarly as the TRI
stuff, and possibly more
musically useful.
Well??!?!?
Re: [motm] MOTM-310 time again
2001-08-31 by Scott Juskiw
I vote for the PWM version (option #2). Static waveforms are too
boring, I'd like to have some manner of altering the waveform via
voltage control.
Re: MOTM-310 time again
2001-08-31 by Mike Marsh
I think I like the second option, because I very much like the idea
of a blend.  But I would also very much like to have the blend under
CV. I would give up PWM for blend!
Mike
interface, I'm
bracket,
> and 4 jacks.
want to
kit) I
> 4 knobs are:
> COARSE
> FINE
> FM (attenuator)
> WIDTH (of pulse)
> 4 jacks are:
> 1V/OCT
> FM
> SAW
> PULSE
SQUARE and
function
looks
> like the best fit.
has 1 OUT.
pulse width
as the TRI
> musically useful.
> Well??!?!?
> Paul S.
2001-08-31 by George Kisslak
On Thursday, August 30, 2001 9:48 PM Paul Schreiber <synth1@...>
Seems like a lot of coughing going on over there.  Everything ok??
OUT.
> The 4th jack is PWM IN. With no plug inserted, the PULSE is 50%.
> Else, the input is a -5V to +5V pulse width control (no input
attenuation).
> the TRI stuff, and possibly more musically useful.
> Well??!?!?
I very much like the concept of manipulating the waveform with CV, so I'd go
for the blend pot and the PWM IN jack.  Definitely more musically useful,
IMO.  Very slick, the normalled PWM jack!  So, if I set the blend to SAW,
what effect does the PWM CV have?  Does it change from saw-up to tri to
saw-down?
Hey, could there possibly be an on board jumper to change the PWM IN jack
between PWM and BLEND?  (I guess there's no room for a switch. Bah!)
George
Re: [motm] Re: MOTM-310 time again
2001-08-31 by J. Larry Hendry
I like Mike's idea of CV control of the blend instead of PWM.  Since blend
is actually changing the shape, it could almost function like PWM since PWM
does change the "shape" of the wave.  Plus this gives us something
"different" from the 300 waves and adds some diversity.
much like the idea of a blend.  But I would also
2001-08-31 by Jeffrey Pontius
Absolutely the blend option.  This would be a very nice feature and would
set the 310 slightly apart from the 300.  I think the extra cost would be
well worth it.
Jeff
> > saw-down?
jack
> > George
> on Thursday, August 30, 2001 11:53 PM Paul Schreiber <synth1@...>
wrote:
> No, the effect is zero. The saw is always fixed-shape.
> Paul S.
Ok.
I like the idea of VC blend - I see a number of others touting it as well.
However, I have a thought about the concept - sort of a long term thought.
If [a big if!] we ever have a VC mixer, couldn't that be used to perform
waveform blending?  Wouldn't it be preferable long term, if a VC mixer is in
the works, to have VC PWM support in the 310, and use a VC mixer to blend
waveforms of a 300 (and others)?
Cheers,
George
2001-08-31 by elhardt@aol.com
groovyshaman@... writes:
waveforms of a 300 (and others)?<<
A VC mixer would be nice, but it is really just several VCA's mixed together.
 So there's no need to wait, you can do it now.
-Elhardt
synth1@... writes:
>>Since this main function of the '310 is to 'beef up' the mix with existing
'300s<<
Perhaps it would be more cost effective to provide an Oscillator Gang module.
 Something like four oscillators on a 3U wide panel with a single set of FM
inputs and mixed audio output.  That will beef up a sound.
-Elhardt
It would beef up my bank account as well!
The '310 schematic is about done.
To: <motm@yahoogroups.com>
Sent: Friday, August 31, 2001 12:03 AM
Subject: Re: [motm] MOTM-310 time again
> synth1@... writes:
existing
> '300s<<
module.
FM
> -Elhardt
2001-08-31 by mark@indole.net
How about an output that goes from saw to square to narrow pulse??  Let's
ignore for a moment whether or not this is controlled from a knob or a
voltage.  The first half of the knob (or from -5V to 0V) goes from saw to
square, the second half of the knob (or from 0V to 5V) contains no saw and
goes from square (50% pulse) to 0% pulse (or 100% pulse, not that it would
make much difference).
So if it were controlled by a voltage, with no input the output would be a
square just like Paul suggests below.  However, this would also give the
option of saw to square blending in addition to VC PWM.
I think one of the best points made in this discussion is that saw to
square blending can be achieved with two VCA's and a mixer (if by
"blending" one means simply summing the two signals, although Paul might
have some other sort of waveshaping in mind), and that MOTM already offers
a mixer and two VCA's.  However, afaik, there is no way to do PWM unless it
is built into the oscillator.
Imho, being able to modulate pulse width with a voltage is much more useful
than being able to set it with a knob.  Now, if it had both a knob and a CV
input, the knob could provide an offset voltage, and the module could
provide a fixed output other than square without using a voltage source.
Although I'd much rather have a 310 with five jacks and three knobs.
>bracket, and pcb size. That means 4 knobs and 4 jacks.
Good for you!!
>keep it SAW-based (as opposed to TRI-based). Looking at the pcb space and
>>cost target ($169-179 kit) I propose the following:
I like triangle waves as much as the next guy, but regardless of cost, saw
is much more practical.
>4 knobs are:
>COARSE
>FINE
>FM (attenuator)
>WIDTH (of pulse)
>4 jacks are:
>1V/OCT
>FM
>SAW
>PULSE
Groovy :)  I didn't like the mock-up I saw earlier that only had TRI and
VAR (saw to square controlled by a knob) outputs.  This new configuration
is much better :)
>TRI) looks like too many parts to fit on the board. Plus it adds $10-$15
>to >the cost. Since this main function of the '310 is to 'beef up' the mix
>with
>like the best fit.
>has 1 OUT. The 4th jack is PWM IN. With no
>>width control (no input attenuation).
That is very clever, but wouldn't you need a square or saw available at all
times to make it a good sync source to use with a mini-wave or 300??
Is there any way to add a fifth jack to output a fixed waveform for use as
a sync source??  What if you lose a knob and go with my dual-function CV
idea??  If the dedicated output were saw, and the variable output without
any CV input is square (as stated in all four proposed designs), wouldn't
that would be the most useful con carne configuration??
Also, jacks cost significantly less than pots.  So if the purpose of this
module is to provide a sync source and beef up the mix, three knobs and
five jacks would work better.  This would also satisfy its requirements as
a space-saving lower cost VCO.
Yes, I agree that saw to pulse blending is more useful than tri to square
blending.  Otoh, tri to saw blending is nice for bass patches.  Then again
you can't have everything :)
2001-08-31 by jasret@mindspring.com
> VCO has 1 OUT. The 4th jack is PWM IN. With no plug inserted,
> control (no input attenuation).  So you can get SAW to PULSE
> musically useful.
> Well??!?!?
I like this one.  A single out for the *micro* VCO should be
sufficient (if it's used as a clock, you'll only need the
PULSE/SQUARE; if it's running a Miniwave, you'll only need the SAW;
if it's used as an audio oscillator, THEN the blend will be useful),
and I find a PWM *jack* more flexible than a PW knob (you can always
use an external CV source to set a fixed pulse width other than 50%).
    -Doug
     jasret@...
RE: [motm] Re: MOTM-310 time again
2001-08-31 by Brousseau, Paul E (Paul)
I hate "me too" posts... but what else is there to say?
Ideally I'd like the output to blend from TRI (-5v) to SAW (0v) to PULSE
(+5v), but its more important to me that there is a blend in general than
the range of the blend.
Once again, thanks for letting us give some input, Paul!
--PBr
Sent: Friday, August 31, 2001 11:45 AM
To: motm@yahoogroups.com
Subject: [motm] Re: MOTM-310 time again
> musically useful.
> Well??!?!?
2001-09-01 by elhardt@aol.com
>>I hate "me too" posts... but what else is there to say?  Ideally I'd like
the output to blend from TRI (-5v) to SAW (0v) to PULSE (+5v)<<
OK, all you people seem to want something different than a basic SAW and
PULSE wave, so you ask for blending and other things that won't make any
noticable difference in your sounds.  Why not then ask for totally new
waveforms.  How about a figure 8 waveform, or maybe one with a bunch of half
arcs riding ontop of a sawtooth that looks like an ocean wave (good for
synthesizing water sounds?).
Let's not forget that the MOTM LFO does blending and can be used as an
oscillator in some occasions.  After you hear the LFO as an audio source and
turn the shape knob for a few minutes, you will shortly tire of it as it's
not as thrilling as you think and then it will no longer be all that
important for the microVCO to have that feature.
-Elhardt
