Custom PCB's !!!
2001-07-22 by thomas white
Check out: www.expresspcb.com I am so happy to have found this place. You choose the level of circuit board quality. All boards have plated throguh holes, but if you pay the difference you can also get solder mask ans top side silkscreen. They even let you write stuff in the copper if you want to go the lower cost route. I will label my board side componenets this way. I want to do a board layout for Barry Kleins CEM3320 Lowpass VCF circuit (fig.5-20 in the book) from Electronic Music Circuits. It will end up a lowpass similar in sound and features to the 440 with the same inputs and VC resonance control. I have already started the pcb design and I hope to be able to find a couple of guys who are down to make a custom MOTM filter module with me. This is the classic filter from the sequential Pro-1/Oberheim misc and has the bass compensation when resonance is increased like the 440 (but on chip) The circuit takes a small amount of parts and the CEM is readily available from Paul. You can get Paul-like circuit boards, but the cost for these is much more expensive with a solder mask or silkscreen. If you pay the difference you will end up with a quality board for sure so I would like to go the more expensive route, but cost then becomes a factor. 4 4 x PCB's of my design on the standard boards is about $110 total. The nice solder masked boards with silkscreen make the total about $350 for 4 boards, but its only $400 for 20 boards so if we can come together on some sort of module we could all share the costs and end up with $20 PCB's of a high order. Even if no one is interested I will go the cheap route wich ends up being about $25 per pcb (when ordering 4). If I end up going through with it I will post the results to you all. Thanks Thomas White PS. Quiet list this weekend right? _________________________________________________________________ Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
