More Power Needed.
More Power Needed.
2001-05-08 by Roy Harter
Hello there fellow MOTM users.
I am new to the list, so if my questions seem redundant, I
apologize.  I am about to exceed my 18 module limit for my MOTM 900
power supply and was wondering if anyone would be interested in
helping me build a larger one.  Thanks to Dave Bradley's website for
making me aware of:
Power One #HCAA-60W-A, +15V@1.0A, -15V@1.0A, +5V@6A
Digi-Key #179-2071-ND, 1-9 $94.00
Power One #HCBB-75W-A, +15V@1.5A, -15V@1.5A, +5V@6A
Digi-Key #179-2072-ND, 1-9 $109.67
I am of very limited technical experience and am actually a little
afraid of messing around with a power supply.  If I purchased one of
the 2 Power One units,  how much modification would be required to
install into my MOTM setup?  If it is difficult or dangerous, would
anyone with more experience and knowledge be interested in building
one for me?  I would of course pay you. If anyone has any suggestions
or interest, please email me.  Thanks for all your help.
Harmoniously Yours,
ROY HARTER
royh@...
Re: [motm] More Power Needed.
2001-05-08 by George Kisslak
Hello Roy, and welcome!
The major issues to consider when determining your power supply requirements
is what the target size of your MOTM system is, and how many cases there
will there be.  If, like most of us, it'll grow for as long as you breathe,
then you should plan ahead and give yourself plenty of power headroom.  Are
you fascinated with blinky lights?  There are some "do it yourself" projects
that add lights to various modules, and since lights eat power, you should
plan accordingly.  If you're planning on more than one case, then you'll
need to distribute the power between the cases - a DIY project.
Alternatively, you can cut the gordian knot and buy a MOTM-900 for each
addl. case.
Alas, anything other than the MOTM-900 is going to be DIY.  Don't worry -
this is part of the fun of building your own modular!  It shouldn't be a big
project.  It's just a matter of mounting a replacement power supply
somewhere within the case, removing the wiring from the old supply (mounted
to the 900) and wiring up the replacement supply in it's place.  The
connections should be the same, albeit longer.  Use shrink tubing, insulated
spade/lug terminals or electrical tape for safety.  I recommend the Power
One dual output supply HCC15-3-A (DigiKey 179-2073-ND) as a replacement
instead of a triple output supply, since MOTM modules do not require the 5V
output.  It provides +-15V @ 3A which should be good for about 80 powered
modules or so.  The MOTM-900 PCB provides only 12 power connectors, so you
may want to pick up a MOTM-960 power distribution board, as it provides 24
connectors.
I have already have more than one 40U case worth of modules, so I plan on
designing a multi-case module-based distribution scheme that will
(hopefully) look the part.  =^)  At some point, I'll put this on my web
site.  Oh... I have to build the web site, too...  Oh well.
Cheers,
George Kisslak
To: <motm@yahoogroups.com>
Sent: Tuesday, May 08, 2001 11:46 AM
Subject: [motm] More Power Needed.
making me aware of:
Harmoniously Yours,
ROY HARTER
royh@...
2001-05-09 by J. Larry Hendry
Don't worry - this is part of the fun of building your own modular!
It shouldn't be a big project.  It's just a matter of mounting a
replacement power supply somewhere within the case, removing
the wiring from the old supply (mounted to the 900) and wiring up
the replacement supply in it's place.  The connections should be the
---LH---
Of course, I see no reason why you could not leave the MOTM-900
power supply in place and attach the switched AC over to source
another power supply.  I don't have a 900, but I seem to recall that
the AC connector is one of those with the fuse built in.  So, you
would need to increase the fuse size to accommodate the additional
load.  I don't think slightly the larger fuse (in the size I am thinking)
would
be an issue for protection.  Certainly, the switch should be fine, but the
rating should be checked.  I cannot imagine it being even close though.
Then, one switch would turn on both supplies.  The only disadvantage is that
if the single fuse protecting both supplies blows, you have to do some
trouble
shooting to know which supply has failed.  But, chances of PS failures are
rather slim these days.
Larry Hendry
