Re: MOTM-130
Re: MOTM-130
2001-03-24 by mate_stubb@yahoo.com
--- In motm@y..., "Paul Schreiber" <synth1@a...> wrote:
> Well, "Ask and ye shall receive."
> Discuss.
> Paul S.
Re: MOTM-130
> Discuss.
Oops. Sorry for the blank post. Well, I drew the sucker, but that
doesn't mean I know how it works!
1. What's the LINK jack for?
2. There are 2 CV inputs per vca - 1 exp, 1 lin - and 1 CV
attenuator. How are those hooked up?
3. How does PAN/FADE mode work - by taking one set of CV inputs, and
inverting them for control of the other VCA?
Moe
MOTM-130
2001-03-24 by Paul Schreiber
Discuss.
Re: [motm] Re: MOTM-130
2001-03-24 by Microtonal
My guess is the link jack might be a way to chain VCA outputs together
without tying up a mixer, sort of like auxiliary inputs that aren't
controlled by the VCA but just mixed in, but then it would seem like you'd
need two link jacks, not one.
John Loffink
microtonal@...
To: <motm@yahoogroups.com>
Sent: Saturday, March 24, 2001 12:19 PM
Subject: [motm] Re: MOTM-130
> > Discuss.
> Moe
Re: [motm] MOTM-130
2001-03-24 by elhardt@aol.com
synth1@... writes:
>>Well, "Ask and ye shall receive." Discuss.<<
It's clear, easy to follow and a thing of beauty. That was until I saw the
Pan/Fade swtich and remembered it also does that. In that mode it is no
longer clear how the module works, what inputs and outputs are used and what
knobs are used for panning and fading. Perhaps some extra labeling is
needed. There's also a little free space for some kind of diagram graphic if
needed.
-Elhardt
2001-03-24 by jhaible@t-online.de
Inputs *and* outputs are normalized so you will always get the desired
pan or crossfade function. Link jack is if you want to combine
more than 2 VCAs.
You always have *both* CV inputs active at the same time, linear and
exponential. In pan and fade mode, the linear CV is used to pan and fade,
and you can still use the expo input for loudness control.
(In other words, there is no need to run a signal thru more than one VCA
in series for panning and yout final synth voice's VCA - the combination
is done in the CV rather than the audio path.)
JH.
2001-03-25 by Microtonal
I would much rather have a LINK1 and LINK2 input so VCA outputs can be
combined independently. This would allow multiple stereo panned signals to
be mixed. Take OUT1 from the previous MOTM-130, plug it into LINK1. Take
OUT2 from the previous MOTM-130, plug it into LINK2. Now the panned mix of
both MOTM-130s is available at the second set of outputs.
If you just want to link (mix) 2 VCAs (nonpanned), then take OUT1 and plug
it into LINK2 on the same module. The mix is now available at OUT2.
This not only saves a mixer module, it also saves unnecessary controls since
there's already GAIN controls at the VCAs.
John Loffink
microtonal@...
Sent: Saturday, March 24, 2001 4:23 PM
Subject: Re: [motm] Re: MOTM-130
> more than 2 VCAs.
> JH.
2001-03-25 by jwbarlow@aol.com
In a message dated 3/24/2001 5:43:40 PM, jhaible@... writes:
>more than 2 VCAs.
I'm under the impression that it is way beyond too late to make any changes
to the 130, but I like John's idea (below). I also may still be a bit
confused (so what's new) about the LINK function. In Juergen's post he
indicated that module's functions would be determined by its input and output
configuration --
1) one input + two outputs is a VCA with VC Pan,
2) two inputs + one output is a VCA with VC Crossfading inputs,
3) two inputs + two outputs is two independent VCAs.
If that's true, can one use either VCA alone, or does one have to choose say
VCA1 as the single VCA? I also wonder how the PAN/VCA MODE switch effects the
module's behavior(assuming the normalizing scheme above is true -- if so it's
an absolutely great use of normalizing jacks IMO)?
JB
In a message dated 3/25/2001 7:52:52 AM, microtonal@... writes:
>to
>of
>since
MOTM-130
2002-02-14 by Paul Schreiber
The MOTM-130 is all designed. It just needs a pcb layout. The "problem" is it has a ZILLION
parts. It's a 30-40hr job. I *haven't had* that block of time available for 5 months.
It *needs* to be done. But it's at least 4 months away.
2010-05-03 by Paul Schreiber
Paul once said that the MOTM-1190 (frac VCA) is the core for the MOTM-130. It looks MOTM-130 might be two VCAs rather than two Q111s.
This is an accurate statement. There is a "linking" circuit to do the pan/fading. It's a JH original design. It' 2 1190s + a bit more.
I just have to be careful in my parts selection going forward, with Analog Devices going all obsolete on me :(
