white, ... noise generating components
2001-03-10 by Jeffrey Pontius
In reading about the white, ... noise generation of the MOTM 101 and the
Oakley noise module, I noticed that the audio noise generation is
implemented in different ways: the MOTM 101 uses zener diodes and the
Oakley uses an npn transistor.
Are there any differences in the audio (or other aspects) of these  2
implementations?
[Note: I'm not interested in comparisons of these 2 *modules*, just that
they have implemented noise in apparently different ways]
Thanks, Jeff
Re: [motm] white, ... noise generating components
2001-03-10 by Paul Schreiber
> implementations?
Well, I'm just being fancy. Using 2 un-correlated noise sources just makes
the noise "whiter",
Gaussian-wise.
2001-03-11 by Jeffrey Pontius
> > implementations?
> the noise "whiter",
> Gaussian-wise.
Are you saying that the white noise is generated according to a Gaussian
(normal) distribution?  I had thought (without knowing the electronics
behind it) that it would conform to a continuous uniform distribution.
Jeff [going back to making 'noise' with his motm]
