Moving right along
2001-03-06 by Paul Schreiber
1) Finished the rough pcb layout of the MOTM-101. I should have it off to the board shop by Wed AM. 2) Decided to set the mixer channel gains a little 'hot'. This is going to be a compromise: you can always change it with a different resistor. No, I'm not adding trim pots, jumpers, panel switches or a FORTRAN complier. 3) The VCA gets the nod after the mixer. Sigh. It should be out in late April. 4) VCO kits are out. It will be end of next week until more are kitted up. Everything else will be kitted up by this Friday. I am trying to flush as many kit orders out this week, because next week it's back to assembled modules. THEN.... the testing/kitting up of the 65 or so '101s on order. It only has 33 resistors, so it's not like the '320 (gack). 5) The errant 113 jacks are spoken for. 6) I'm also out of size L shirts. More are coming in, as well as a batch of hats. Everyone needs at least 1 of these. Paul S.
