Re: [motm] Re: Battle over
2001-03-04 by Tony Allgood
>it would be a custom job to get a pot that reacted in log fashion for
half its travel, and in reverse log fashion for the other half, no?
You can do this with a load on the pot wiper, say a 10K resistor on a
100K pot. But I think a linear pot is better for most uses.
Tony Allgood  Penrith, Cumbria, England
My music: www.mp3.com/taklamakan
Re: Battle over
2001-03-04 by mate_stubb@yahoo.com
You can make a case for reversing attenuators in the audio side as
well - for instance I want to mix waveforms from a single VCO, and
want to do so both out of phase and in phase.
I think I understand where you are coming from, however - it would be
a custom job to get a pot that reacted in log fashion for half its
Moe
--- In motm@y..., "Paul Schreiber" <synth1@a...> wrote:
> Then on the left column, these are 100K Bourns panel
> pots and A is normal and
> B & C are reversing attenuators. You want reversing atenuators to
be linear,
> anyway!
Battle over
2001-03-04 by Paul Schreiber
Thanks for all the Mixer suggestions. Here is the "final" decision:
a) Mixer model is 830, as in MOTM-830
b) Moe inage #1 is the design: a bias switch, and a switched jack. The
reason I like the
jack is that it minimizes wiring, and is sort of slick, imho. I don't see a
need for switches/LEDs
as certainly you know if a patchcord is plugged into OUT 1 or not.
And if you want to play reconfiguration games 'on-the-fly-, look at the
MOTM-700. That's what it's for :)
c) Now, since I am *assuming* that 95% of the time, this is an audio mixer,
then I propose that
the D/E/F inputs (the right column) all 3 be log pots. The reason they have
to be over there is that
the are pcb mounted. Then on the left column, these are 100K Bourns panel
B & C are reversing attenuators. You want reversing atenuators to be linear,
anyway!
Well?
Re: Battle over
Fearless Leader has spoken! New image up at:
http://motm.retrosynth.com/moe_stuff/future_motm/m-830.jpg
Moe
The
> reason I like the
don't see a
2001-03-04 by jhaible@t-online.de
Unity gain buffer amp drives cw end of pot. Inverting amp drives
ccw end. Middle connection of pot is output, and loaded to GND
by a smaller resistor. For 100k pot, 30k load. Not truely exponential,
but better than linear.
You can also load the pot with two identical resistors to both ends.
This works in that other Reversible Attenuator configuration (with
the pot at the input of a differential amp).
JH.
2001-03-04 by jwbarlow@aol.com
In a message dated 3/4/2001 12:22:24 PM, oakley@...
writes:
I'm not sure if this is what Tony meant, but it might be a better choice to
go linear on all pots (or Juergen's idea on all the pots -- nice to see you
back JH!) if only for the uniformity of operation. Correct me if I'm wrong
here guys, but this module seems to be more of a "pre-mixer" (since there's
no output level controls) in that levels wouldn't typically be adjusted on
the fly. The inputs might have a "touchy" quality to them, but I'd think that
would be less strange than "pot 1 operates this way, pot 2 operates a little
differently, and pot 3 operates differently still!"
In fact, it might be nice to have reversing attenuators on all the inputs (I
can hear Paul groan from here) -- hey Moe, great idea about mixing waves from
the same VCO!
JB
Re: Battle over
2001-03-04 by GeorgeK
I just thought I'd throw in my two cents...
The
> reason I like the
don't see a
I agree with the switched jack concept. No need for a switch or LED
as you can simply tell by looking. I don't have an issue with either
OUT1 or OUT2 for "splitting" the mixer, a case could be made for
either one. Overall, simple and intuitive. That said, switches/LEDs
are always nice (but more parts = $$).
audio mixer,
> then I propose that
they have
panel
be linear,
> anyway!
Reversing attenuators for E & F would be nice! <ugh>
GeorgeK
Re: [motm] Battle over
2001-03-04 by Microtonal
Well, not to be nitpicky, but I would want the bias pot to be on the left
column and mixer, since that side is more likely to be used with control
voltages (linear pots and reversing attenuator).
I would definitely like to have log pots on the right side mixer.
John Loffink
microtonal@...
To: <motm@yahoogroups.com>
Sent: Sunday, March 04, 2001 2:13 PM
Subject: [motm] Battle over
> reason I like the
a
mixer,
> then I propose that
have
linear,
> anyway!
> Well?
> Paul S.
Re: Battle over
John has a point. Since the BIAS pot must be on the right side due to
physical constraints, how about if the LEFT side had 3 log pots with
range 0 - 10, and the RIGHT side had 3 linear pots, two of them
reversing.
Then mixer 1 is optimized for audio, pot taper wise, and mixer 2 is
optimized for cvs with reversing attenuators and the bias knob.
Paul, is there any practical reason that the log pots can't go
offboard?
Moe
the left
control
> John Loffink
> microtonal@w...
I'll see if it fits mechanically. And, in it's current position the BIAS pot
is pcb mounted. Less wire, less labor.
Sent: Sunday, March 04, 2001 4:13 PM
Subject: Re: [motm] Battle over
> John Loffink
> microtonal@...
> > reason I like the
see
> a
> mixer,
> > then I propose that
> have
panel
> linear,
> > anyway!
> > Well?
> > Paul S.
2001-03-04 by The Old Crow
  The majority of pots, when possible, go on the right side for
circuit-board reasons.
Crow
In a message dated 3/4/2001 2:33:31 PM, mate_stubb@... writes:
>offboard?
Will the switch clear the PCB? I bet Paul already has the pots and they are
board mounted which I find to be a hassle mounting offboard.
JB
Re: Battle over
New image, with audio mix on left, cv mix on right:
http://motm.retrosynth.com/moe_stuff/future_motm/m-830r2.jpg
Moe
to
with
> reversing.
> offboard?
> Moe
RE: [motm] Battle over
2001-03-05 by Tentochi
I like the version with the 3X2 and 6X1 switch.  Excellent for live
performance IMHO.  It looks cool on Moe's mock-up too!
--Shemp
> -----Original Message-----
> From: Paul Schreiber [mailto:synth1@...]
> Sent: Sunday, March 04, 2001 3:14 PM
> To: motm@yahoogroups.com
> reason I like the
> don't see a
> audio mixer,
> then I propose that
> they have
> be linear,
> anyway!
> Well?
> Paul S.
