MiniWave
MiniWave
2001-03-02 by andy@gooboworks.com
Blacet has a Preliminary MiniWave graphic on his web site.   Check it
out.  It looks interesting.
http://www.blacet.com/MW.html
Andy
Re: [motm] MiniWave
2001-03-02 by Dave Hylander
Yahoo!!  We're getting closer!!
Re: Blacet MiniWave
2001-03-02 by mate_stubb@yahoo.com
Based on that graphic, it is identical to the current MiniWave
featurewise with the addition of a bank attenuator (also present on
the Stooge panel), and a second set of banks, for twice the number of
tables. Cool!
I'd still like to see that 8/6/4 bit "Grunge" switch feature...
Moe
it
> Andy
Re: Blacet MiniWave
2001-03-02 by ceres@sirius.com
If you're getting custom wave EPROMs made, you could always design
waves with "lower resolution".
In fact, that makes me think that one cool possibility for a wave
bank would be one that starts with a smooth sine wave (wave 0), which
becomes a "stair-stepped" (lower resolution) sine wave (waves 1-14),
that eventually turns into a square wave (lowest possible resolution -
 wave 15).
    -Doug
     ceres@...
RE: [motm] Re: Blacet MiniWave
2001-03-02 by Tentochi
Does the Wiard Mini-Wave morph from one wave to the next as on PPGs and
Waldorfs?
Thanks!
Shemp
> tables. Cool!
> Moe
Re: Blacet MiniWave
and
> Waldorfs?
> Thanks!
> Shemp
Technically no, not in the sense that you specify a beginning
waveform and an ending waveform, and the module fills in intermediate
waveforms on the fly.
You CAN sweep via CV through 16 waves in a single bank. Several of
the banks in the stock ROM are set up to do a morph from wave 0 to
wave 15. They don't calculate the intermediate waves on the fly - the
intermediate steps are already burned into the ROM, but the audio
effect is still the same. If you set the input switch to bipolar mode
( +/-5V ), the module allows switching from one wave to the next only
on zero crossings, so you don't get audio glitches as it changes
waves.
So practically, yes you CAN morph, you just are limited to whatever
is burned into the ROM, and 16 waves per morph max. If the timbre
shift is drastic from one end to the other, you will hear some
timbral stepping, since 16 waves isn't always enough. This is why the
idea of a ZIF socket and ROM burner is attractive - designing your
own custom morph banks.
Moe
MiniWave
2001-08-29 by jpotter@it.rjf.com
I don't suppose any of you would want to sell me your Stooge version
of the Blacet/Wiard Mini-Wave would you?  I'd even be willing to pay
a bit of a premium.  I was too late to the game for the initial order.
If you do send me a note at chupacba@...
JP
