M-181 Panel
M-181 Panel
2001-02-26 by thomas white
Hi Shemp!
Here is a picture of my DIY panel up as close as I could get. The features
are as follows:
Din cable that brings original Roland CV/Gate and Trigger signals to the
panel. On the panel there is a 1/4" jack for each of these signals. With the
extra space I put in a switch and 4-jack multi above both the CV and Gate
outs. The switch allows for the multis to link to the cv and gate out so you
end up with 5 outs from each signal or 2 x 4way multis.
A simple but very effective module in my 3 VCO, 4 EG setup. I used to have
to patch out of my cabinet to a different multiple I have and back again,
but this panel made it all go away. I would love to replace my laser-printer
stick on panel label with a true silk-screened panel. Maybe we can stir up
enough interest to get this one thrown into the 3rd panel run? There have to
be other M-181 owners who might like this project. It is really simple and I
actually did all of the MOTM required gate voltage mods on the panel and
left my M-181 stock. Works great and it would be even easier for those who
did the mods inside the M-181.
Hope you dig it,
Thomas White
PS. I have thought about adding a "Gate On" led in the blank space on the
front panel, but I want to wait to see my total current in this cabinet
before I go crazy with this LED and Dave B's mods for the 800 EG's.
Get your FREE download of MSN Explorer at http://explorer.msn.com
Re: [motm] M-181 Panel
2001-02-26 by sikorsky
hello all,
to show solidarity, i'd probably order one of these panels...
...although, i'd almost certainly want to go inside my 181 and swap the
trigger out for the bend out
the wiring is a little tight in there, so not many would want to have a go
i currently just use a 3 core mains cable to run the power to the 181 which
i retrofitted with prehdin (locking din) sockets, all the CV stuff just
comes out the 1/4" jacks on the back, with a couple on miniature 1/8" CV
monitor jacks plugged in the top
however, something i am planning, is to just build a simple switching CV
interface, a three way, rotary switch, with inputs for pitch, gate & bend
for two or more devices ie 181 or midicv - a useful little tool, as i
currently have to repatch multiples which frankly gets on my tits
cheers
paul b
RE: [motm] M-181 Panel
2001-02-27 by Tentochi
Excellent!  I am sure many others enjoyed the post and picture too.
I am down with doing a panel run.  I may even be willing to kit up a few if
there is enough interest--say 5 people.  This would also work for the Roland
M-182 and M-184 I believe.
Is anyone else interested?  It sounds like we have 3 already.
Cheers!
Shemp
> features
> are as follows:
> signals. With the
> out so you
> used to have
> laser-printer
> can stir up
> There have to
> simple and I
> those who
> Hope you dig it,
> Thomas White
