Milter-greylist
Index last updated: 2026-04-28 23:32 UTC
milter-greylist-4.2.7
2011-04-13 by manu@netbsd.org
Here is our latest stable release:
http://ftp.espci.fr/pub/milter-greylist/milter-greylist-4.2.7.tgz
From Changelog:
        Fix wrong message size tracking, causing bug in spamd (Attila Bruncsak)
        Fix ratelimit sliding window for computing average
        Fix p0f port byte order (Enrico Scholz)
        Fix milter-greylist.m4 for newer Sendmail (Joe Pruett)
        Fix autoconf warning about --datarootdir (R P Herrold)
        Add spamassassin toggling to the .spec file (Adam Katz)
        Fix DKIM (John Wood, Jörgen Lundman)
Emmanuel Dreyfus
http://hcpnet.free.fr/pubz
manu@netbsd.org
Re: milter-greylist-4.2.7
2011-04-13 by gitoshi
don´t compile in Centos 5.6 with bind97
dnsrbl.c:205: undefined reference to `__ns_initparse'
dnsrbl.c:211: undefined reference to `__ns_parserr'
./configure --enable-postfix --enable-dnsrbl --with-user=postfix --with-libbind=/usr --enable-spamassassin
> From Changelog:
> Emmanuel Dreyfus
> manu@...
Re: [milter-greylist] Re: milter-greylist-4.2.7
2011-04-14 by manu@netbsd.org
They are probably in another library. Could you look for it with nm?
Emmanuel Dreyfus
manu@...
2011-04-14 by John Wood
Looks like libresolv:
# nm libresolv.a | egrep 'ns_initparse|ns_parserr'
         U __ns_initparse
         U __ns_parserr
000000a0 T __ns_initparse
000002c0 T __ns_parserr
>          U __ns_initparse
>          U __ns_parserr
Nothing new, then. I will need your config.log, to track that one down.
Emmanuel Dreyfus
manu@...
2011-04-14 by gitoshi
here the config.log (in the group files)
http://f1.grp.yahoofs.com/v1/ABqnTQU8ym9428meG0hyUXFNN_tZH27AFiAhhAvCg4lYCBscDD2i52XkfnPcrM-Ed2pWe8Xr_kRugmvXYdOXbvIAKLp43w/config.log
> >          U __ns_initparse
> >          U __ns_parserr
> Emmanuel Dreyfus
> manu@...
2011-04-15 by manu@netbsd.org
HTTP 404...
Emmanuel Dreyfus
manu@...
2011-04-15 by gitoshi
in yahoo groups left panel Files
or
http://www.megaupload.com/?d=PGIMM0AY
> HTTP 404...
> Emmanuel Dreyfus
> manu@...
2011-04-16 by manu@netbsd.org
You get this:
LDFLAGS=' -L/usr/lib -Wl,--rpath=/usr/lib'
LIBS='-lbind9  -lpthread -lresolv -lnsl -lmilter'
Please  run this to check where the mussing symbol is:
nm /usr/lib/libbind9.so | grep initparse
nm /usr/lib/libresolv.so | grep initparse
Emmanuel Dreyfus
manu@...
2011-04-17 by gitoshi
nm: /usr/lib/libbind9.so: no symbols
0063dc90 t __ns_initparse
> You get this:
> Emmanuel Dreyfus
> manu@...
2011-04-18 by manu@netbsd.org
How strange: the symbol is local!
Try running nm -D on the various .so, just in case.
Emmanuel Dreyfus
manu@...
2011-04-18 by gitoshi
nm -D /usr/lib/libbind9.so | grep initparse
nm -D /usr/lib/libresolv.so | grep initparse
version 4.2.5 compile without any problem
here the version 4.2.5 log
http://www.megaupload.com/?d=4GM7Z5QX
> Emmanuel Dreyfus
> manu@...
2011-04-18 by Enrico Scholz
manu-S783fYmB3Ccdnm+yROfE0A@... writes:
fwi, ns_initparse is exported only by the static libresolv.a; the dynamic
libresolv.so does not export this symbol.
This has been changed in more recent glibc's, but for RHEL5 you
have to link against 'libbind.so' (not 'libbind9.so'!!) from the
'bind-libbind-devel' (not from 'bind-devel'!!) package.  Link order
is very tricky in this combination (else, libresolv and libbind
might get mixed and cause mysterious crashes).
The fedora package should do the right thing by specifying the '--with
libbind' rpmbuild option, but I abandoned RHEL5 on my mail filter some
time ago and can not say how/if it still works.
Enrico
look like bind 9.7 don´t provides libbin.so anymore
yum provides */lib/libbind.so
30:bind-libbind-devel-9.3.6-16.P1.el5.i386 : Include files and library needed to use the BIND resolver library.
Repo        : base
Matched from:
Filename    : /usr/lib/libbind.so
yum provides */lib/libbind9.so
32:bind97-devel-9.7.0-6.P2.el5.i386 : Header files and libraries needed for BIND DNS development
Repo        : base
Matched from:
Filename    : /usr/lib/libbind9.so
30:bind-devel-9.3.6-16.P1.el5.i386 : Header files and libraries needed for BIND DNS development.
Repo        : base
Matched from:
any idea??
--- In milter-greylist@yahoogroups.com, Enrico Scholz <enrico.scholz@...> wrote:
> Enrico
2011-04-19 by gitoshi
ok I solved the problem patching Makefile and link to /usr/lib/libresolv.a
don´t need libbind anymore
here my build options
./configure --enable-postfix --enable-dnsrbl --with-user=postfix --enable-spamassassin --with-thread-safe-resolver
look like a problem with RHEL 5.6 libresolv.so library
# nm /usr/lib/libresolv.a |grep initparse
         U __ns_initparse
# nm /usr/lib/libresolv.so |grep initparse
> Repo        : base
> Matched from:
> Repo        : base
> Matched from:
> Repo        : base
> Matched from:
> any idea??
> --- In milter-greylist@yahoogroups.com, Enrico Scholz <enrico.scholz@> wrote:
> > manu-S783fYmB3Ccdnm+yROfE0A@ writes:
> > Enrico
2011-04-20 by manu@netbsd.org
If someone gets a clean configure patch, the contribution is welcome.
Emmanuel Dreyfus
manu@...
