Milter-greylist
Index last updated: 2026-04-28 23:32 UTC
Sending ACL id string to syslog, instead of ACL line number
2009-04-15 by John Thiltges
Hi all,
I recently upgraded to milter-greylist 4.2.2. I was looking forward to
using the feature of adding an id string to ACL entries and easily
gathering detailed stats on which rules were matching.
However, it appears that the default syslog output includes the
configuration line number only, and not the id. The 'stat' keyword could
be used to create an additional logfile. But, I'd prefer to have that
information in the existing maillog.
Attached is a patch to replace the logging of ACL line number with ACL
id string (if an id is specified). It uses fstring_expand(..., "%a") to
build the string.
I'd be happy to hear other suggestions of how to collect ACL statistics.
John
Example syslog output where an id of 'CBL' is defined:
Apr 15 15:18:20 server milter-greylist: n3FKIIpx012305: addr
[127.0.0.1][127.0.0.1] from <nobody@...> to <nobody@...>
delayed for 01:00:00 (ACL CBL)
Example syslog output where no id is defined:
Apr 15 15:18:20 server milter-greylist: n3FKIIpy012305: skipping
greylist because this is the default action, (from=<nobody@...>,
rcpt=<nobody@...>, addr=example.com[127.0.0.1]) ACL 212(none)
Re: [milter-greylist] Sending ACL id string to syslog, instead of ACL line number
2009-04-16 by manu@netbsd.org
> build the string.
I committed it on head, you will have it in 4.3.1
Emmanuel Dreyfus
http://hcpnet.free.fr/pubz
manu@...
2009-04-17 by manu@netbsd.org
> build the string.
What tabout the performance impact of this change? Now we go to
fstring_expand() regardless of the existance of an ACL id string, and
that function at least performs two mallocs. Perhaps we should test for
it before entering fstring_expand()?
Emmanuel Dreyfus
manu@...
2009-04-17 by John Thiltges
Would it be better to make aclstr[] a larger static buffer and not use
fstring_expand()?
Example:
char aclstr[HDRLEN];
if (priv->priv_sr.sr_acl_id)
    snprintf(aclstr, sizeof(aclstr), " (ACL %s)",
        priv->priv_sr.sr_acl_id);
else if (priv->priv_sr.sr_acl_line != 0)
    snprintf(aclstr, sizeof(aclstr), " (ACL %d)",
        priv->priv_sr.sr_acl_line);
else
    aclstr[0] = '\0';
-John
> fstring_expand()?
> Example:
> else
>     aclstr[0] = '\0';
Well, this gets suddently much less readable :-)
Emmanuel Dreyfus
manu@...
2009-04-21 by John Thiltges
>> fstring_expand()
I agree on the readability.
How about changing fstring_expand() to work like snprintf()? Passing a
destination buffer could (hopefully) avoid a malloc/free.
-John
