"milter-greylist: greylist: thread_create() failed: 12" errors
2007-09-26 by marknreynolds
Hi, I have a very busy milter-greylist implimentation running on SuSE 9 which I suspect is running out of process memory. The mail log shows ""milter-greylist: greylist: thread_create() failed: 12" errors" which goes away when I restart the process. I am not a programmer, however I have been logging the number of threads milter-greylist is creating and have seen it go up to 290. If I run pmap on the process I can see each thread is taking 8M of memory so by the time I multiply 8M by 290 and add on the size of the greylist database (around 300MB) I am starting to approach 3GB which I believe is the limit for user space memory within a process. I am currently waiting for the next errors so I can confirm how many threads were open at the time. Have I hit a physical limit or is there any tuning I can carry out to prevent the problem re-occuring? Any thoughts appreciated Regards Mark Reynolds
