Re: [gsp-2101] Digest Number 988
2014-12-16 by James E. Simons
try cleaning the actual jack with DeOxit 5%.. if that does not do it, examine the solder joints on the PCB for cracks.. if cracked, reflow the existing solder joints.. it could also just be that the jack itself has worn out and is not creating good contact and must be replaced..
On Sunday, December 14, 2014 6:03 AM, "gsp-2101@yahoogroups.com" <gsp-2101@yahoogroups.com> wrote:
There is 1 message in this issue.
Topics in this digest:
1. Outputs give different levels Show quoted textHide quoted text
Message
________________________________________________________________________
Posted by: josejuangallego@... josejuangallego
Date: Sat Dec 13, 2014 12:53 pm ((PST))
HI,
My GSP2101 (updated to Artist) is giving the following problem:
One of the outputs is giving the signal about -10db lower than the other. Checked cables, that was not the problem. Tried both outputs (jack and canon) and the same result. It´s the mono/left channel that is now low-level and noisy.
I use to use the unit with both connectors (jack and canon) plugged simultaneously for this output. Tried both settings, both cables connected, and only canon connected, and same result: level reduced and noise appears when gain is applied in the mixing desk.
Any hint from any technician/experienced user here?
Thanks in advance,
J.
Messages in this topic (1)
Yahoo Groups Links
