> It is pretty straight forward. From the manual...
> Â
> ⢠Using the Parameter [NEXT] / [PREV] keys, scroll to parameter you want to assign to a function key,
> ⢠Press and hold Function key [1] for about two seconds.
> ⢠Select the Program screen location where you want the Parameter to appear by pressing Function key [1], [2], or [3].
> After youâve selected a location in the Program screen for the Parameter, the GSP-2101 Artist
> returns to the place in the Parameter menu where you left off.
> If you decide you want to change the Function key assignment for that Parameter, repeat the
> process, and select a different location. If you want to leave a Parameter with no Function key
> assignment, press its assigned Function key again, and the Function key will be disconnected
> from the Parameter. After you've made your Function key assignments, youâll need to store the
> Program in order to retain the changes.
> From: Steven Vachon <prometh@...>
> To: gsp-2101@yahoogroups.com
> Sent: Mon, June 7, 2010 12:01:42 AM
> Subject: [gsp-2101] Re: Main screen shortcuts (for 1,2,3 buttons) ?
> Â
> By the way, I'm referring to the 1,2,3 buttons on the front of the unit, not the foot controller
> --- In gsp-2101@yahoogroups.com, "Steven Vachon" <prometh@> wrote:
> > I have looked at the manual, but I must've missed it. I tried pressing and holding the MIDI button, but the 1,2,3 buttons are not listed in there
> > --- In gsp-2101@yahoogroups.com, C Mead <stratburst@> wrote:
> > > Take a look at the manual. These buttons can be assigned to any program parameter.
> > > From: Steven Vachon <prometh@>
> > > Sent: Sun, June 6, 2010 6:19:13 PM
> > > Subject: [gsp-2101] Main screen shortcuts (for 1,2,3 buttons) ?
> > > ÃÂ
> > > I'm noticing that some programs have shortcuts on the main screen, accessed by the "1", "2" and "3" buttons. They're shortcuts to things like Gain1 and MVol. To see an example of this, load up program #64 (or #164). They seem to be present in both my user and factory programs. I'm wondering how to create and remove these. Thanks
