EXS 24 Logic Sampler Users Group group photo
Index last updated: 2026-04-28 23:25 UTC
Merging programs
Merging programs
2003-03-13 by Hans Hafner
Hi there,
I don't know if this has been covered, I didn't find it in the
archive, maybe I chose the wrong words...
is it possible to merge two or more presets into one, or do I have to
use CDXtract to do that?
Thanks for the help
Cheers
Hans
Re: [EXS] Merging programs
2003-03-14 by Hendrik Jan Veenstra
I suppose you mean that you want to take 2 EXS programs, and create a
new one where the original 2 are layered, right?  I don't see what
cdextract would have to do with that...  Just load the 1st program in
the EXS and open the Instrument Editor.  Load the next program in the
EXS, and open another Instrument Editor window.  In the 1st editor,
select all, copy, and in the 2nd editor window paste.  Then 'save as'
new program name.  Rather straightforward, isn't it?
Hendrik Jan Veenstra  <h@...>
Omega Art: http://www.omega-art.com
2003-03-14 by Hans Hafner
Why do I never try the most obvious thing....??????
Thank you very much, my life is a lot better now!
Cheers
Hans
Because you're human :-)
2003-03-14 by bob_vandiver
Sir Hendrik schreib
a
in
as'
OK, but what if I want to import a set in which one bank is selected
by one key and the other by a second?
The problem I see is: take bank 1, change group 1 to "select by" and
designate your key. Now I want to add layer 2. Open that bank and its
editor. Change that group to "select by" and name another key.
However, both banks are set to group 1. How do you make the second
bank go to a second group before the merge (doing so afterwards
would, I would think, be rather labor intensive)?
Inquiring minds......
Bob Vandiver
Sir Hendrik schreib
a
in
as'
Bob Vandiver
2003-03-15 by Hendrik Jan Veenstra
Not sure if I understand your question correctly (the use of the word
'bank' in the context of the EXS which doesn't have banks confuses
me), but: if you have 2 EXS programs in which the zones are assigned
to one group, and you then copy/paste everything (zones plus
belonging group) into a new editor window, you'll end up with 2
layers of zones, where each layer is assigned to its own group (since
you copied the group _with_ the zones when doing the copy/paste).
It's then fairly easy to change the 'select by' definition of the 2
groups.
I.e. the trick is to have the original instruments set up properly,
grouped and all.  Copying and pasting duplicates the original
structure, so that it's easy to select the original layers in the
composite instrument.
If I misunderstood your question, please give it another try :-).
2003-03-15 by Bob Vandiver
> groups.
No you got it essentially correct Hendrik. I am not sure if I understand you
though either. Let me see if I got it right, Program 1 with its zones are
sent to group 1 in its editor window, Program 2 with its zones assigned to
its group (also group 1). Select all in 2, paste into editor for program 1.
Does the group  1 of program 2 increment upon pasting to group 2
automatically?
BobVandiver
2003-03-16 by Sascha Franck
> automatically?
Yes.
Sascha
2003-03-16 by Murray McDowall
> automatically?
If you have named your groups they retain their names when pasted, if they are
simply numbered (the default) then the numbers will be revised -- you won't
have two "Group 1"s.
Murray
2003-03-16 by Bob Vandiver
Thanks Murray, Sascha and Hendrik!
Bob
"See, we love ‹ we love freedom. That's what they didn't understand. They
hate things; we love things. They act out of hatred; we don't seek revenge,
we seek justice out of love." ‹George W. Bush, Oklahoma City, Aug. 29, 2002
Brings tears to the eyes...
> From: Murray McDowall <murraymc@...>
> Reply-To: exs-users@yahoogroups.com
> Date: Sun, 16 Mar 2003 15:08:01 +1100
> Subject: Re: [EXS] Merging programs
>> automatically?
> Regards,
> Murray
> To unsubscribe from this group, send a blank email to:
> exs-users-unsubscribe@egroups.com
> For a list of places to get free samples please see:
> http://groups.yahoo.com/group/exs-users/links/
