exs with phatboy controller
2001-11-27 by andy scott
hi folks anyone shed some light on this one? i get a patch up on the exs, tweak some stuff with the phatboy, decide that i dont like it, reload the patch, or even load an entirely different one, and as soon as i go to tweak anything, the whole patch is reset to the previous, discarded settings. in the environment i have an exs transformer with all the correct mapped CC's assigned, the first box on the first line in the map is set to = control, and the third box on the second line of the map is set to map. as far as im aware everything is as should be. ive also tried taking the phatboy out of the chain and using the mod wheel on my keyboard to do the tweaking, with the same results - i had the mod wheel set to control the filter cutoff, i tweaked a bunch of stuff with the mouse, i loaded another patch into the exs, hit the mod wheel, and all parameters were reset again to the previous patch's tweaks. mystified andy lamp 4.8.1
